Control valve
/ Control valve #1
benkapitanec
I'll be in the market for a control valve for my log splitter project. I've noticed that control valves come rated in different GPM ratings. The pump I will be using is rated at 28GPM, powered by 16hp. Do i buy a control valve that is rated the same as the pump? Not really knowledgeable about this. Can someone offer some advice?
/ Control valve #2
Yes, your valve should be rated the same or very close to the GPM of the pump-you could get away with a 25GPM rated valve. You also need to size the hoses, filter and reservoir properly also.
I assume it is a two-stage pump you are using?
/ Control valve #3
If you buy a valve get one that locks in on the return stroke so you can do other things when the cylinder is returning.
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2015 KENWORTH T880 TOTER TRUCK (A65643)
2015 KENWORTH T880...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2020 Chevrolet Traverse SUV (A64557)
2020 Chevrolet...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
