Backhoe Control valve leakes
/ Control valve leakes #1
Dslate
Kansas City MO
Bobcat CT 235
I have a 6TB backhoe attached to my CT235. The control valve is leaking and I would like to rebuild it but the rebuild kit is over 3,000.00 through Bobcat. Its a old Rhino backhoe but they don't make them any more. Anyone have any ideas as to how I could get parts other then through Bobcat?
/ Control valve leakes #2
The one piece valve is not serviceable. 3k is for new valve that replaces it.
/ Control valve leakes #3
I would seek out a hydraulic shop for parts options or a more reasonable and newer style serviceable replacement control valve.
/ Control valve leakes #4
Define the leak?
Is it leaking oil externally? If so.....its probably just common 50 cent o-rings that seal the spools.
If its leaking internally.....meaning weak hydraulics....stuff leaking down.....etc.....then that isnt something that is serviceable on any common spool valve....and replacement is the only solution
/ Control valve leakes #8
Looks like it is the "Valve, Section Float" on the second section". Bobcat has the part for
about $1,000. I'll try agaparts.com see if they have it any cheaper.
That's still way too much, IMO.
As a benchmark, you can replace your whole hoe valve stack with a 12 GPM Prince 6-spool setup from
Surplus Center for $800. There is an active thread on TBN right now on that.
My hoe valve leaks now, too, but it will have to leak more before it becomes a repair
necessity.
JOHN DEERE 9420R ARTICULATING TRACTOR (A64280)
JOHN DEERE 9420R...
Decorative Mermaid Light Post (A61574)
Decorative Mermaid...
Caterpillar 941/951B/955 Maintenance and Service Manuals (A63117)
Caterpillar...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
