Backhoe Control valve leakes
/ Control valve leakes #1
Dslate
Kansas City MO
Bobcat CT 235
I have a 6TB backhoe attached to my CT235. The control valve is leaking and I would like to rebuild it but the rebuild kit is over 3,000.00 through Bobcat. Its a old Rhino backhoe but they don't make them any more. Anyone have any ideas as to how I could get parts other then through Bobcat?
/ Control valve leakes #2
The one piece valve is not serviceable. 3k is for new valve that replaces it.
/ Control valve leakes #3
I would seek out a hydraulic shop for parts options or a more reasonable and newer style serviceable replacement control valve.
/ Control valve leakes #4
Define the leak?
Is it leaking oil externally? If so.....its probably just common 50 cent o-rings that seal the spools.
If its leaking internally.....meaning weak hydraulics....stuff leaking down.....etc.....then that isnt something that is serviceable on any common spool valve....and replacement is the only solution
/ Control valve leakes #8
Looks like it is the "Valve, Section Float" on the second section". Bobcat has the part for
about $1,000. I'll try agaparts.com see if they have it any cheaper.
That's still way too much, IMO.
As a benchmark, you can replace your whole hoe valve stack with a 12 GPM Prince 6-spool setup from
Surplus Center for $800. There is an active thread on TBN right now on that.
My hoe valve leaks now, too, but it will have to leak more before it becomes a repair
necessity.
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2016 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2016 Eager Beaver...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
