Backhoe Control valve leakes
   / Control valve leakes #1
Dslate
Kansas City MO
Bobcat CT 235
I have a 6TB backhoe attached to my CT235. The control valve is leaking and I would like to rebuild it but the rebuild kit is over 3,000.00 through Bobcat. Its a old Rhino backhoe but they don't make them any more. Anyone have any ideas as to how I could get parts other then through Bobcat?
   / Control valve leakes #2
The one piece valve is not serviceable. 3k is for new valve that replaces it.
   / Control valve leakes #3
I would seek out a hydraulic shop for parts options or a more reasonable and newer style serviceable replacement control valve.
   / Control valve leakes #4
Define the leak?
Is it leaking oil externally? If so.....its probably just common 50 cent o-rings that seal the spools.
If its leaking internally.....meaning weak hydraulics....stuff leaking down.....etc.....then that isnt something that is serviceable on any common spool valve....and replacement is the only solution
   / Control valve leakes #8
Looks like it is the "Valve, Section Float" on the second section". Bobcat has the part for
about $1,000. I'll try agaparts.com see if they have it any cheaper.
That's still way too much, IMO.
As a benchmark, you can replace your whole hoe valve stack with a 12 GPM Prince 6-spool setup from
Surplus Center for $800. There is an active thread on TBN right now on that.
My hoe valve leaks now, too, but it will have to leak more before it becomes a repair
necessity.
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
