I don't understand my tractor's hydraulics yet. If I wanted to run a continuous hydraulic flow, for example to run a hydraulic tool, can I do that with my New Holland TN75? Can I add something to do it? Thanks.
Just a word of caution, keep an eye on your oil temperature. If your oil cooler and reservoir are not sized for continious duty you can overheat the system and damage seals etc...
Roy
For this intended use, I would an auxiliary oil cooler in the power beyond loop after the "hydraulic tool".
bad idea. The power beyond more than likely feeds the 3 point. Which means there is still high pressure after the "added tool".
Unless you have a return to sump line that you are sending the return oil too, then it would probably be ok.
