Tractor Sizing Contemplating the 4105
/ Contemplating the 4105 #1
kry226
Pennsylvania
Looking
Long time lurker here...
As stated, I am looking at the 4105 and after reading lots here, I wanted to get some feedback regarding this tractor for my specific desired uses.
I own 240 acres in the flatlands of the Texas Panhandle, with about 180 acres of that in CRP (the rest is woods) that requires mowing as part of my conservation plan. In fact, mowing will be its largest chore with a few miles of "ranch roads" to keep under control and just over a mile of road frontage. But the required mowing is also not something I will ever need to be in a hurry to finish.
I'll also use it to move the occasional brush pile, pull the occasional smallish stump, haul corn out to feeders, or haul the occasional deer back to the shed. I do not plan on heavy tillage other than maybe a food plot or smaller garden. I don't want bigger for the sake of time efficiency, but would only want bigger because the 4105 just won't keep up with my expected tasks and uses. If it takes me a few days or a dozen to cut the 180 acres, I'm OK with that.
I am particularly interested in the 4105 for the HST and lack of fru-fru, but also because I can find this tractor in packaged deals for what "seems" like pretty good prices. Take this package for example:
$27,998.00 advertised price
4105 Tractor
John Deere 300 CX Loader
Insulated Canopy
6' Box Blade (with scarifiers)
6' Rotary Cutter (with Slip Clutch & Front Shields)
Post Hole Digger (with 9" Auger)
20' Trailer (Brakes, Ramps, Ramp Racks, Diamond Plate Fenders, Tube Top Rail, Bulldog Hitch)
I know you guys get threads like this all the time, but I appreciate any feedback given. Thanks!
/ Contemplating the 4105 #2
With that much mowing I think I would be looking for something at least in the five series and a eight foot rotary cutter. Even with a eight foot rotary cutter you will be getting more seat time than is enjoyable. Never ran a rotary cutter in Texas, but have talked to some people that have and they advised it was a very - very hot dusty thing to do. I think you would be asking a lot of the 4105.
/ Contemplating the 4105 #3
I would lookk into a new 5000E series wi the cab and larger mower. That much mowing with a small open station will become drudgery and I can't prove right off but suspect a larger tractor and mower would be more fuel efficient too.
Lots of guys get on here and think a cab is too expensive or that they "don't need that" only to come back on here at a later date to trade up. Buy it right the first time, it's cheaper. At any rate the new E series with cabs should be just what you need and a higher hp model should turn a large brush mower. I am expecting the simpler E series to be less cost than the M by a good margin.
My next door neighbor has a place in Spearman by the way.
/ Contemplating the 4105 #4
With that much mowing I think I would be looking for something at least in the five series and a eight foot rotary cutter. Even with a eight foot rotary cutter you will be getting more seat time than is enjoyable. Never ran a rotary cutter in Texas, but have talked to come people that have and they advised it was a very - very hot dusty thing to do. I think you would be asking a lot of the 4105.
I agree 100%, anything smaller than 8' and you will be needing to start cutting the second time,before you finish the first cut. A 10' cutter would be a better choice I think,but you will need more HP than a 4105.
Thanks, gents, I appreciate it.
However, I should have been more clear with the CRP in that it only requires mowing every few years. I'll be managing for wildlife and will never arbitrarily "cut the whole thing." But also, please know that I am not trying to come here to only get my idea validated. I am not emotionally bought into the 4105. I just came across it and what seemed like a good deal on enough tractor. So keep up the suggestions! I definitely know about buy once, cry once. Been there, done that.
My actual routine mowing will be the road frontage and trails. A couple of swipes with the six footer would suffice for both. Also, I am really partial (though not adamant) to a hydro as the wife and kids may be cutting their teeth on on whatever tractor I buy too.
Thanks again!
P.S. Mr. Steve, I've never been through Spearman, it's way north of me.
Kyle
/ Contemplating the 4105 #6
I bought mine in a package it has been real good tractor. My frontier shredder doesn't really throw dust on me.
The only trouble I have had is with neutral safety switch . The best thing I have done to it was to put vertical exhaust on it.
Thanks, 99.
I have seen the vertical exhaust mentioned a couple times. Is this done to reduce heat or fumes for the operator? Also, do you see any HP issues with my intended uses? I think I am just about set on hydro, and if I could get a hydro on a 5E series, I think the discussion would be over.
From the advice above, I started looking at higher HP units and I really like the 4x20 series, but even a used 4320 with only a modest bump in HP from the 4105 still runs in the high $20s to low $30s. But I also found that the MX5100HST (gasp) is pretty reasonably priced used in the lower $20s, though I don't really expect any endorsement of orange here. The Mahindra 5035HST looks promising as well. I wish JD filled this gap a little better with a 50ish-HP, no frills HST tractor.
Any other thoughts? And thanks!
/ Contemplating the 4105 #8
I put they stack on for the fumes it really does help be cause before the engine fan would blow them back at you.
As far HP for your jobs this tractor will surprise you. I shred in high range,pull up trees,carried big fallen oak
Pulled some buddy's out of mud. So far it has done every job I throw at it.
Thanks for the feedback! I really want to go with a JD as the dealer is only about 40 miles from me, and closer than any other dealer.
/ Contemplating the 4105 #10
kry226,
I know it is more money buying into a 4320 through 4720 series but you would be getting alot more tractor too. I should mention the three range ehydro with economy pto in the 4520 and 4720 would be very useful in your locale for clipping pastures compared to the 4105. Most of the pastures are thin compared to the deep south where I used to live and required more pto hp to keep the blades turning up to speed. In your locale you could make good use of the epto at a reduced engine speed of 1740 rpm for most of your cutting. This assumes using a 6' 3pt cutter, I have a hunch the larger 8' and 10' cutters are going to be more than you want to spend.
As far as frills and fru fru goes I don't consider things such as three range ehydro, larger fel, better hydraulic options, planetary rear end, more weight, steering brakes, larger tires and a cab to be frills. While a 4520 cab is more money it is alot more tractor than the 4105, since you want a hydro machine that is what I would recommend.
kry226,
Sir,
Thanks for your advice. First, I want to ensure my fru-fru comment wasn't offensive. That wan't my intent, and I guess I am just a little frustrated that this process is becoming, from my perspective, an all or nothing gig. I really like the plain jane hydro (with cruise!) of the 4105, but I do wish it had a little more umph for unforseen tasks I may find in the future. But the bells and whistles of the 4x20, while certainly useful, in many ways seem unnecessary for my intended uses. I certainly don't want to under-buy, but I don't want to over-buy as well. Again, buy once, cry once.
But again, I'll only need to cut my pasture in its entirety every few years. The rest is simply trail and road frontage maintenance. So my dilemma remains. If the 4105 works fine for my intended uses, the money saved can go a long way toward other implements.
However, I did a 4105-4320 comparison this morning and the differences (other than horsepower) were obvious. The 4320 is much more of a tractor in terms of PTO efficiency, torque, and lift capability. Room to grow, and obviously moreso with the 45 and 47.
I really appreciate the advice and experience from the forum, but I tell you, you make it no easy task to select a tractor! Looks like I am leaning toward the 4x20...for now. :) Thanks again!
/ Contemplating the 4105 #12
Sir,
First, I second what Steve said about the 4x20s. Second, we went over the 4105 with another individual who was looking to buy one not too long ago. However, this individual was comparing a 3x20 to the 4105 and choose the 4105 due the larger tires and ground clearance. Nonetheless, during that conversation, BleedGreen, who is a JD dealer, provided some very good information below about the 4105 tractor that you should be aware of:
The 4105 is built off the basic 3x20 Series frame and axles. The additional ground clearance is from the larger tires but it also limits rear axle capacity.
The 4105 does not have a metal hood or fenders. If you put a 3x20 Series and 4105 next to each other, especially looking from the back you can see that they are basically the same machine with less features.
The 4105 is a good solid tractor, but you will be limited to many of 3x20 specs and tasks with this tractor. While the 4105 will handle everything now, you might find overtime that you wish you had that little extra to handled those newer heavier duty tasks that need to be tackled.
Please find attached the full spec sheet comparing the 4105 to the 3320 and 3520.
/ Contemplating the 4105 #13
I priced the 4120 first for price of it I was able to get 3 implements,trailer, tooth bar for bucket. The 4120 started at 27000 I paid 26000 all of that. I drove both it was hard decision. I didn't really like the computer controlled hydro pedals.
I don't regret it a bit buying the 4105.
Good luck :)
See what I mean! Tough decision indeed.
I feel the 4105 will accomplish all I need it to right now, but admittedly, there isn't room to grow into the heavier tasks as already mentioned. The 4x20 may be more than I need right now, but obviously it can handle many more of the unpredictables possibly encountered in the future.
I appreciate everyone's insight, advice, help, and patience too. I guess I'll just have to keep thinking and researching, and of course, listening. I'll be out at the property early next month and I'll be definitely evaluating its future upkeep a bit differently. If there is anything else that needs mentioning, bring it on. I appreciate it.
/ Contemplating the 4105 #15
Don't want to start a brand war, but I am in the same boat as you. I love John Deere, but to get the horsepower, size tractor, 4x4, and hydro and am leaning towards a Kubota MX4700. 48 horsepower and I was quoted around $24k with fel.
/ Contemplating the 4105 #16
Something to keep in mind. If you only will be mowiing every few years the extra HP needed for the taller grass will likely shorten the life on the equipment. On my 5103 I see a difference when I cut for the first time verses the end of season. For me it's not a problem as I don't have anywhere near the acreage you do.
Good luck.
Great points, every one.
I think I am almost certainly convinced that I need to be at least in the neighborhood of 50 hp for my intended uses. I really appreciate everyone's input and advice, and if there is anything else that needs mentioning, I am still all ears.
/ Contemplating the 4105 #18
Yeah, I tried to mow 50 acres with the 4105 a couple years back (first tractor) and found out real quick I need something with a cab. To me the bugs and dust was torture. At the very least I'd go with a cabbed 4320...
/ Contemplating the 4105 #19
My only question would be if you think you're going to use the tractor in the winter. The last time I was at Pantex in December, the temperature was 18 degrees with horizontal snow. Seems like the panhandle gets hammered pretty good in the winter. We have a niece that lives 20 miles south of Amarillo so we watch the weather in that area.
If you are thinking you may be working outdoors in the winter - a cab would be worth every penny to me.
I really don't foresee using the tractor much in the winter except out of pure necessity to dig out of a heavy snow, or as I mentioned earlier to maybe haul a deer back to the shop. While I am sure I'll enjoy the heck out of a cab, I really can't justify the extra cost with the exception of happening across a smoking deal that's too good to pass up.
At the end of the day, this tractor will simply help me keep the property maintained. No plans to farm or hay, just road frontage and trail upkeep with a pasture mowing every few years. But I understand that chores may change and I am open to selecting a larger tractor to meet those unforseen needs.
