Contemplating and SCUT
/ Contemplating and SCUT #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
This would replace my aging garden tractor. But, I'd like a factory cab!
My initial internet search finds only Deere with an SCUT with factory heated cab. Anyone know any others?
/ Contemplating and SCUT #3
I think most manufacturers make a cabbed SCUT? Can't think of one off the top of my head that doesn't?
Thanks for the input. I need to clarify. The size I'm looking at is Kubota BX, Deere 1 series or LS MT-1 series. I've found cabs available in the next size up, as Jeff showed, but besides the Deere 1 series, I'm not finding anything else with a factory cab option.
/ Contemplating and SCUT #5
Looked at them all. If you have a link, share it. We may be talking different size tractors? Look at the models I reference above as a reference.
/ Contemplating and SCUT #8
These are all sub compact tractors I have listed.
/ Contemplating and SCUT #9
Most can come with heated cabs, just call the dealer and ask. Now the only small tractor that comes with both heat and AC is the Kubota 2650. Now some small tractor like first level types dont always have eat, but i think most do
/ Contemplating and SCUT #10
Thanks for that. I combed the LS USA website and found no mention of a cab.
If this is not factory, it seems very well done by the pictures.
I'll have to ride over to my local dealer and talk to him. I'd buy another LS in a heart beat! That MT-1 is right at the size I'd like to be too.
219 LS Tractor MT125 W/Heated Cab and Front Snowblower | Outdoor Motor Sports
Here is a link for the LSMT1 series tractor with heated cab. It really depends on the area of the country that will determine if the dealers even KNOW if a cab is available. Out here, they don't even know they are available because of the lack of 'want' by the customers
/ Contemplating and SCUT #12
Why does it need to be a factory cab? Curtis and tektite make nice cabs.. The only factory cabs I have seen on a SCUT is Deere, Mahindra.. I guess there are others but I never saw them..
/ Contemplating and SCUT #13
I had a B series with a cab B26XX and while it was nice I quickly learned that it was top heavy. Small tractor, narrow track and lighter weight thus the cab with made the center of gravity high made it dicy on any slope. I went back to a BX 2680 open. If I were to get a cab on a tractor and if I had more property and younger, I would go the next size up LX I think or M as they are heavier and have a wider track
/ Contemplating and SCUT #14
Only factory cabs below 30 hp is the Kubota 2650, that is built designed and installed by kubota, Kioti has a factory cab that is installed later by dealer. Other cabs are nice and ok, but they usually look blocky
/ Contemplating and SCUT #15
Can we ask why you want the cab in such a small machine?
Most of the folks I see are small lot homeowners that want something to move snow with in the winter.
/ Contemplating and SCUT #16
I would take a tektite over a factory cab.. The Curtis doesn't look as nice..
Yes, I want a cab for blowing snow.
/ Contemplating and SCUT #18
After-market cabs can compare to "factory" and if it doesn't have air conditioning,you don't want it.
/ Contemplating and SCUT #19
Did you even look at the other tractors in the links?
Omg.
Lol.
/ Contemplating and SCUT #20
Omg.
Lol.
You read what I said Lol. I believe the only factory cab for under 30 hp tractors is the 2650, yes kioti has a field cab and other may have field cabs, or cabs that come with it, but what that is, is just a curtiss cab or something that factory either bolts on or ships to dealer to have installed, so essentially its aftermarket, not saying thats bad or not good, just there is only one true factory cab in the smaller tractors
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
CAT 735/740 Final Drive (A68134)
CAT 735/740 Final...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PORTA POTTY (A68842)
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A67714)
2013 ORTEQ ENERGY...
70" Padfoot Shell Kit (A68134)
70" Padfoot Shell...
