contaiminated diesel
/ contaiminated diesel #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hey Guys,
You have always been a good sounding board, and I wanted to see if you could help me with this?
My 1995 M5400S diesel tractor, I accidentally introduced the wrong 5gal plastic containter and by the time I noticed, a lot of "dark sediments" were put into a now full tank [20 gals when full].
Wanted to know what is the best thing to do? I have been checking and changing the fuel filer container...anything else?
Thank you very much,
tstex
/ contaiminated diesel #2
Not knowing what was in there gives several ways to go.
One, drain the tank from the lines just in front of the filters and replace with good fuel.
Two, stock up on fuel filters and try to run it out!
Three, if it might be alge get some algecide to add to the tank.
I always recommend having extra filters on hand as it is a variable for replacement at times like this.
/ contaiminated diesel #4
I would drain it into multiple 5 gallon tanks and filter it through coffee filters as I drained it. I would never run your tractor with crappy diesel.
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2009 MANITOU OASIS PONTOON BOAT (A63290)
2009 MANITOU OASIS...
Attention (A57148)
Attention (A57148)
6 Row Do-All (A64047)
Deutz D3006 Tractor (A62613)
Deutz D3006...
