Grapple Construction Attachments from Everything Attachments
/ Construction Attachments from Everything Attachments #2
Do a search on TBN for grapple. If you are a speed reader you may get through all the info in about a week. :rolleyes:
I was a little vague - was looking for input on that particular grapple. I have utilized the search function and researched the Markham/Gator grapples; however, the small one seems too light and the HD one too heavy for my tractor. The 9TL loader on my CT445 is rated at 2050lbs @ 500mm in front of the pins, IIRC.
My uses would mostly be land clearing, brush gathering, kudzu root molesting, etc. In that case, I suppose I should be calling it a "brush grapple", but the terms seem largely interchangeable.
Just want something that matches my loader capabilities and wondered if anyone had input on that particular grapple.
Thanks,
John K.
/ Construction Attachments from Everything Attachments #4
Ok, that one looks pretty good and Construction Attachments makes some pretty good stuff. I have a heavy duty unit from Unlimited Fabrication, but Unlimited Fabrication does have a std duty unit. It is a bit bigger than what a lot of guys on TBN like though.
Sorry that I can't be of more help, good luck with your decision.
Thanks, Brian! Lots of good info to digest on this site. I hadn't seen that manufacturer before - will check them out.
I think I will also call Gator and talk to them before I pull the trigger. I have read where they have incorporated mods for customers in the past.
/ Construction Attachments from Everything Attachments #6
/ Construction Attachments from Everything Attachments #7
/ Construction Attachments from Everything Attachments #8
CA makes decent stuff, and seems to be sensitive to weight/strength as related to the size/caacity of what an attachment is attached to. Bigger and heavier sometimes is not better. I just yesterday recieved a CA toothbar from Everything Attachmennts. It seems to be well-suited to the tractor it will be bolted to. My ordering/delivery experience with EA was good.
Unused 2021 CID POTSS Skid Steer Quick Attach Conversion Tractor Attachment (A66734)
Unused 2021 CID...
PORTA POTTY (A68842)
1997 Angler 220 Walkaround Boat with T/A Aluminum Boat Trailer (A66738)
1997 Angler 220...
CLUBCART CART (A66091)
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
