Grapple Construction Attachments from Everything Attachments
/ Construction Attachments from Everything Attachments #2
Do a search on TBN for grapple. If you are a speed reader you may get through all the info in about a week. :rolleyes:
I was a little vague - was looking for input on that particular grapple. I have utilized the search function and researched the Markham/Gator grapples; however, the small one seems too light and the HD one too heavy for my tractor. The 9TL loader on my CT445 is rated at 2050lbs @ 500mm in front of the pins, IIRC.
My uses would mostly be land clearing, brush gathering, kudzu root molesting, etc. In that case, I suppose I should be calling it a "brush grapple", but the terms seem largely interchangeable.
Just want something that matches my loader capabilities and wondered if anyone had input on that particular grapple.
Thanks,
John K.
/ Construction Attachments from Everything Attachments #4
Ok, that one looks pretty good and Construction Attachments makes some pretty good stuff. I have a heavy duty unit from Unlimited Fabrication, but Unlimited Fabrication does have a std duty unit. It is a bit bigger than what a lot of guys on TBN like though.
Sorry that I can't be of more help, good luck with your decision.
Thanks, Brian! Lots of good info to digest on this site. I hadn't seen that manufacturer before - will check them out.
I think I will also call Gator and talk to them before I pull the trigger. I have read where they have incorporated mods for customers in the past.
/ Construction Attachments from Everything Attachments #6
/ Construction Attachments from Everything Attachments #7
/ Construction Attachments from Everything Attachments #8
CA makes decent stuff, and seems to be sensitive to weight/strength as related to the size/caacity of what an attachment is attached to. Bigger and heavier sometimes is not better. I just yesterday recieved a CA toothbar from Everything Attachmennts. It seems to be well-suited to the tractor it will be bolted to. My ordering/delivery experience with EA was good.
2021 Ram 1500 SLT Crew Cab Pickup Truck (A61568)
2021 Ram 1500 SLT...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 KENWORTH T680...
2016 Ford F-550 4x4 Mason Dump Truck (A61568)
2016 Ford F-550...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61568)
2016 Peterbilt 579...
