constant pull
/ constant pull #1
Anonymous Poster
Epic Contributor
I am wanting to know if using the TC40 hydrotransmission to pull an implement, such as a 10 ft. disc, will cause damage to the transmission or overheat the fluid.
/ constant pull #2
A 10' tandem disc will probably overload the TC40D. Actually, t would probably be too much for a TC40 gear drive as well. The hydro will not pull as much as a similarly powered gear drive tractor.
/ constant pull #3
If you have sandy soil you may be able to do it but it is a lot of disk to pull. I use a 10' with a TN 65 and my soil is heavy with some clay and it works the tractor. I could probally pull a 12' if everything was nice and dry but if I find a wet spot with the 12' I would have to lift it and avoid it or get stuck going thru. Best bet would be to find a 8' transport disc as the old rule of thumb was 5-6 hp per foot of disc.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
