Connecting non-standard hitch to my tractor
   / Connecting non-standard hitch to my tractor #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I bought a Berkelman off road dump trailer a while back. I am just now wanting to put it into service for some firewood work.
I went to connect it to the tractor and ... whoa ... I'm not sure how to do it? Here is a pix of the front tongue of the trailer. The end section that will take a pin will spin 360 degrees?
How would you connect it up?
   / Connecting non-standard hitch to my tractor #2
Must be so if the trailer flips it won't flip the ATV?
On edit: Sorry I didn't know you have never used your draw bar before, I thought you were asking why it spins 360..
   / Connecting non-standard hitch to my tractor #3
That's a standard draw bar setup. Just slip the drawbar in between the forks and slip a pin through it.
Thanks! I've attached implements but never used a drawbar. Now to see if I have one ....
   / Connecting non-standard hitch to my tractor #5
If you don't have one of these sticking out from beneath the rear axle, you can purchase one of these and attach it to the 3 pt.
Thanks! I know I have the second bar that is pictured. I'll connect it up tomorrow and see how it fastens up!
   / Connecting non-standard hitch to my tractor #7
If you use the 3 point drawbar with a trailer, you need to chain the 3 point arms down or you can get in a situation where the trailer lifts the arms along with the bar. A belly bar is the best way to go with it.
   / Connecting non-standard hitch to my tractor #8
You'll be more stable over rough/uneven ground if you go with a draw bar.
That is very helpful, thank you. I looked at several of their videos looking for something like this. Yes, this one shows exactly how to do it. Perfect.
UPDATE: I found my (cab) tractor has a belly bar. (Did not check the SCUT yet.) It was pushed all the way forward, invisible unless you crawl under the tractor. I extended it backward and it will be the perfect matchup for the trailer. Thank you all again.
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2021 Spartan SRT-XD Zero Turn Mower (A50860)
2021 Spartan...
2016 Ford F450 (A49461)
2016 Ford F450...
2017 Ford Explorer XLT SUV (A48082)
2017 Ford Explorer...
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
