Connecting non-standard hitch to my tractor
   / Connecting non-standard hitch to my tractor #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I bought a Berkelman off road dump trailer a while back. I am just now wanting to put it into service for some firewood work.
I went to connect it to the tractor and ... whoa ... I'm not sure how to do it? Here is a pix of the front tongue of the trailer. The end section that will take a pin will spin 360 degrees?
How would you connect it up?
   / Connecting non-standard hitch to my tractor #2
Must be so if the trailer flips it won't flip the ATV?
On edit: Sorry I didn't know you have never used your draw bar before, I thought you were asking why it spins 360..
   / Connecting non-standard hitch to my tractor #3
That's a standard draw bar setup. Just slip the drawbar in between the forks and slip a pin through it.
Thanks! I've attached implements but never used a drawbar. Now to see if I have one ....
   / Connecting non-standard hitch to my tractor #5
If you don't have one of these sticking out from beneath the rear axle, you can purchase one of these and attach it to the 3 pt.
Thanks! I know I have the second bar that is pictured. I'll connect it up tomorrow and see how it fastens up!
   / Connecting non-standard hitch to my tractor #7
If you use the 3 point drawbar with a trailer, you need to chain the 3 point arms down or you can get in a situation where the trailer lifts the arms along with the bar. A belly bar is the best way to go with it.
   / Connecting non-standard hitch to my tractor #8
You'll be more stable over rough/uneven ground if you go with a draw bar.
That is very helpful, thank you. I looked at several of their videos looking for something like this. Yes, this one shows exactly how to do it. Perfect.
UPDATE: I found my (cab) tractor has a belly bar. (Did not check the SCUT yet.) It was pushed all the way forward, invisible unless you crawl under the tractor. I extended it backward and it will be the perfect matchup for the trailer. Thank you all again.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
1996 Mack RD688S Cab and Chassis (A50860)
1996 Mack RD688S...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
