Connect-Under-Pressure, Breakaway Quick Connect
/ Connect-Under-Pressure, Breakaway Quick Connect
As the terrifying saying in academic medicine goes; "see one, do one, teach one."
Pictures help greatly.
/ Connect-Under-Pressure, Breakaway Quick Connect #23
So you tried putting the male coupler in without the female being mounted?? This would be extremely difficult. I believe that the female side needs to be installed before you are going to be able to couple them. You are talking about this type of coupler, correct? :confused3:
Yup, that type. Parker 9006-001. Attempted with the females mounted in the bulkhead and the bulkhead clamped in the bench vise.
/ Connect-Under-Pressure, Breakaway Quick Connect #24
Well, something some where is wrong,:eek: because they sure are not intended to be difficult to use. If fact they should be relatively easy.;)
/ Connect-Under-Pressure, Breakaway Quick Connect #25
Maybe they just need to have the retainer balls coated with a good dose of hydraulic oil.
IAW the desires for pix, here's one NOT installed in the bulkhead.
1063 (A63291)
1063 (A63291)
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
iDrive TDS-2010H...
2016 CASE TR340 Track Loader (A63111)
2016 CASE TR340...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2017 International 4300 Box Truck (A62613)
2017 International...
