Connect-Under-Pressure, Breakaway Quick Connect
/ Connect-Under-Pressure, Breakaway Quick Connect
As the terrifying saying in academic medicine goes; "see one, do one, teach one."
Pictures help greatly.
/ Connect-Under-Pressure, Breakaway Quick Connect #23
So you tried putting the male coupler in without the female being mounted?? This would be extremely difficult. I believe that the female side needs to be installed before you are going to be able to couple them. You are talking about this type of coupler, correct? :confused3:
Yup, that type. Parker 9006-001. Attempted with the females mounted in the bulkhead and the bulkhead clamped in the bench vise.
/ Connect-Under-Pressure, Breakaway Quick Connect #24
Well, something some where is wrong,:eek: because they sure are not intended to be difficult to use. If fact they should be relatively easy.;)
/ Connect-Under-Pressure, Breakaway Quick Connect #25
Maybe they just need to have the retainer balls coated with a good dose of hydraulic oil.
IAW the desires for pix, here's one NOT installed in the bulkhead.
2015 Chevrolet Silverado 2500HD Service Truck (A61573)
2015 Chevrolet...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
2339 (A64281)
2339 (A64281)
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
