connect a hose to an IBC tote
   / connect a hose to an IBC tote #11
I run around with a 300 gallon tank on a 2 wheel trailer and use a 1-1/2 sump pump hose for my mulched trees. I carry a dozen 5-6 gallon buckets with a 3/8" hole in the bottom edge. The hose is big enough to fill the buckets fairly quick. Still, it is a lot of moving buckets from tree to tree but if I just left a bucket at a tree the hole would plug up to easy and i would be unplugging it all the time. Interesting thread and am looking to make my system even easier.
Next time, put the hole on the side of the bucket.
   / connect a hose to an IBC tote #13
I use an IBC tote and plumbed it to a 12v on demand pump. From there it's connected to a normal hose. I squeeze the hose nozzle and the pump self primes and pumps at around 40psi. Plenty of pressure. I tow the IBC on a trailer and pull it with the Polaris side x side. Longest time spent is filling up the IBC.
   / connect a hose to an IBC tote #15
If it has the camlock fitting you can get a male camlock to female NPT and reduce it down to accept a hose bib.
   / connect a hose to an IBC tote #16
If I remember right, there are three different set-ups for IBC totes. Camlock, 2"NPT and some square thread.
I got a 2" NPT to 3/4" hose thread adapter off of Amazon...not the cheapest but was the easiest for 2A.M. shopping! Wherever I got mine from had adapters for all three set-ups.
Wow! I love this site! So many great ideas I had not even considered. I simply hoped to find out how to connect a hose. Had not even thought about all the other options. Thank you, thank you, thank you!
   / connect a hose to an IBC tote #18
I also found an adapter for my tote. Volume through a water hose is no problem; you'll have plenty of pressure. Here's a picture of my adapter. DSCN0225.JPG
   / connect a hose to an IBC tote #19
This is what I have for water supply in the back 40. Bought a rubber tub and put a kitchen sink strainer drain in it. So when it rains it goes straight to the tote. 5 gal. bucket fits under the spigot.20180827_170752.jpeg
   / connect a hose to an IBC tote #20
We catch rain water from the garage and shop into 2 330 gal containers for watering the grass. Fittings into the ball valves were under 10 bucks at the local industrial supply house. Aluminum is cheaper than the plastic ones. I found an old swimming pool pump on Craigslist, hooked a 2"gise into it and came our with the 3/4" spigot head. Great for watering the lawn and flower beds. I use my skid steer to move a full tote to the garden and use a 2000 watt 12 V DC to 120 V AC inverter to run the pump at the garden.
Club Car Carryall 500 Utility Cart (A59228)
Club Car Carryall...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
