connect a hose to an IBC tote
   / connect a hose to an IBC tote #1
Buxus
Maryland
Kubota M7060
I have about 100 trees I plan to plant in remote spots on my property. I have grown them for two seasons in my nursery and they are about 3-4 feet tall. My experience has been that by planting in September the plants need minimal irrigation, but not zero irrigation. I usually just turn a hose on low volume and run it for about 15-30 minutes at the base of each.
In order to use a hose for these I'd have to run over 1000 feet of hose to some of them. I am thinking of using IBC totes on my forks and just setting one on the ground next to each grove of plants and let the water gravity-feed each plant from a hose connected to the IBC tote.
I have never seen an IBC tote up close. Is there an easy way to connect a garden hose? Do I need to epoxy a hose bib into the opening? Any ideas welcome.
   / connect a hose to an IBC tote #2
Never used any myself but the totes I've seen are usually fitted with a ball valve. You should be able to find a reducer/adapter to fit and use as you want. Here is a site listing some IBC Tote valves.
   / connect a hose to an IBC tote #3
If the tote doesn't have an existing place to connect, get a bulkhead fitting in the size you want and connect your own valve.
Just drill a hole and use a stiff wire to feed the inside part of the fitting into place, then screw the outside nut on. There's a gasket for the inside, so you should be able to keep the inside piece from spinning.
Amazon.com: Lifegard Aquatics 3/4-Inch Double Threaded Bulkhead: Pet Supplies
   / connect a hose to an IBC tote #4
They usually have a valve and NPT male connection (2”). A couple of adapters from Homer and a hose bib you’re good to go. Just made one myself for refilling my buckthorn sprayer.
   / connect a hose to an IBC tote #5
I use IBC totes for irrigation on my gardens. Most of the IBC totes have a valve with a 2" quick connect fitting. Some have a valve with a 2" NPT thread. You can get adapters to connect them a garden hose on FleaBay or Amazon.
   / connect a hose to an IBC tote #6
We plant a lot of trees for shelterbelts. I started out setting two totes on a hay rack and then dragging hoses around to the trees. All the totes I've seen have a valve or a provision for one.
My current set up uses a 3/4" electric solenoid valve. I have a small loader with forks and I wired up a momentary push button switch. So now I can drive up to the tree, hit the switch for about 15 seconds, and drive on.
   / connect a hose to an IBC tote #7
I have a handful of PVC fittings glued together to reduce size. I assume its 2" NPT, but havent bothered remembering since I built it a few years ago. Ends in a brass hose spiggot.
   / connect a hose to an IBC tote #8
I do this too, but with out the valve, I’ll have to add that to mine. I use 5 and 2-1/2 gallon buckets setting next to the plants with a small hole in the bottom, just fill the bucket and move on , the small hole let’s the water run out very slow so it soaks in and not run off.
   / connect a hose to an IBC tote #9
I'm with countryb on this. Gravity fed takes a lot of your time and most of the water will run off. Put a 3/16 hole in the side of a 5 gallon bucket and up a few inches from the bottom. The water that remains in the bucket will make it more likely to stay put when the wind blows. Or put a big rock in the bucket to accomplish the same thing.
I tried your plan for watering 235 new potted trees for my windbreak years ago. It might be good for you but it wasn't good for me.
I ended up finding some free mulch to put around the trees and did the watering with a 330 gallon water tank, 12 volt bilge pump that I dropped in it with a short garden hose and a toggle switch to shut it off when moving to the next tree.
   / connect a hose to an IBC tote #10
I run around with a 300 gallon tank on a 2 wheel trailer and use a 1-1/2 sump pump hose for my mulched trees. I carry a dozen 5-6 gallon buckets with a 3/8" hole in the bottom edge. The hose is big enough to fill the buckets fairly quick. Still, it is a lot of moving buckets from tree to tree but if I just left a bucket at a tree the hole would plug up to easy and i would be unplugging it all the time. Interesting thread and am looking to make my system even easier.
Honda utv cart (A56859)
Honda utv cart...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2018 Ford F-150 (A55973)
2018 Ford F-150...
golf cart (A55758)
golf cart (A55758)
19088 (A55758)
19088 (A55758)
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
