Concrete Pad Slope
/ Concrete Pad Slope #1
JDGREEN4ME
Southeast PA
John Deere 2520, John Deere X534, GT 225, GT 275
We are adding a 12' x 24' pad next to our pole barn. Planning on a 1" drop across the 12' width to keep water away from the barn. Is that enough? too much? Thanks...
/ Concrete Pad Slope #2
I think it's more than enough fall for a 12' wide slab.
/ Concrete Pad Slope #3
Not enough, standard slope is 2% or 1" over 4 feet. That would be 3 inches. Bare minimum on a perfectly finished pad is 1% or 1/8" over 4 feet which would put you at at least 1.5 inches.
/ Concrete Pad Slope #4
I am with you. I have heard 1/4" drop/12" which is the same as you recommended. That amount of slope should eliminate all/most standing water unless the cement is very uneven.
/ Concrete Pad Slope #5
1% would be more than enough, 2% would be to much in my opinion.
As long as that 1% can be maintained, not heave up from frost.
Sanitary sewers are at 1% so it's more than enough.
Especially if you want to work on things under there, you don't want it to be so out of level.
JB.
/ Concrete Pad Slope #6
For an outside pad next to a building I would go with a 1 inch in 4 foot fall. And probably a little steeper depending on the terrain. But never any less than that.
/ Concrete Pad Slope #7
That's even greater than 2%, Is this going to be a wash pad for cleaning heavy equipment?
Why would you need the water to shed so quickly?
Concrete patios where you would have furniture etc, would typically be 1/8" per foot. My stone patio is only 1" over 16 ft, and never a puddle even right after a heavy rain, of course there are joints everywhere so that helps.
For OP with a 12' wide pad, I would go 1.5 inches or a little over 1%, would provide good watershed and still not be to far out of whack to work on.
I'm speaking from experience on not having to much pitch on a pad. I built a large truck port on the side of my shop and made the slope some where around 4-5 inches in the 20 feet wide asphalt paved surface. It's a pain in the neck working on things that far out of level.
JB.
/ Concrete Pad Slope #8
I poured a front porch slab off the front of my house that was 20' and 12' deep or 12' out from the house and gave it exactly 1" of fall over the 12' and have never had a problem, if you were pouring a slab for a hog parlor or a skinning rack I could understand more fall, but water doesn't tend to run uphill.:D
/ Concrete Pad Slope #9
If you want to get technical 1/4 per foot slope is 2.1%, 1/8 per foot is 1%. 2% fall is the standard used for landscape archetecture. Will 1% work, sure but you stand a greater risk of standing water depending on the finishing job and backup during a heavy rain. You have to ask, are you more concerned with runoff/water issues or having a more level place to work? Then make the call. Either way im sure 1.5 inches would be ok.
/ Concrete Pad Slope #10
That's just what I was going to say. I just went out and measured some of my concrete and I am sticking to my story. 1 inch in 4 feet for a 12 foot wide slab against a building and outside. Most of my stuff is 1&3/4 inch drop in 4 feet. I work on it a lot and never had a concern but I also have a spot about 20 foot square that is level and that comes in handy at times. Its primary job is to move water away from the building. Any other use should be secondary. If we move the slab away from the building then the rate of fall could lesson depending on the intended use.
/ Concrete Pad Slope #11
I like a pad sloped so a trailer, truck, etc., can run one side up on a 3/4 or 1 1/2 inch board and then be level.
Bruce
/ Concrete Pad Slope #12
Sewage lines are 3 to 7 percent slope with 5 percent being the easy number to keep things flowing nicely.
For an outdoor pad, I would want 2 to 3 percent. Water will stick to the concrete and not flow if it's too gentle a slope unless you have a lot of water coming down. Give it enough slope to get it away from the house.
Eddie
/ Concrete Pad Slope #13
Around here sewers go down to 1% or 1.2" per 10 feet. To much pitch and the solids seperate from the liquid. only 4 inch house sewers have a minimum of 2%. Actually the large main trunk sewers are far less than 1%. they have to be, there's no way to maintain any more pitch in flat topographical areas. The treatment plant is 8 miles away but only 50 feet lower than here. At 5% you would only get 1/4 mile before that 50 feet would be used up.
But closed sewers are much different than slabs,
So as far as the pad goes I guess alot would depend on location, I imagine in sunny Florida even if the slab was dead level it would be dry 20 minutes after a rain. If the slab were in a harsh freezing environment then the higher end of the pitch recommendations here would be in order.
JB.
/ Concrete Pad Slope #14
I hate it when I make a level slab and the rain just piles up on it so I need waders!
:D
Bruce
/ Concrete Pad Slope #15
:D
Bruce
I formed up a little slab for my tractor shed, about an oversized 1 car garage.
Really just one form across the front at the apron, I fussed and fussed with it getting it just right. Then when the concrete truck came, he drove close to the form, with the ground being soft it heaved up about 2 inches. Of course I didn't realize it at the time. It ended up making the apron outside the door have the slightest reverse pitch.
I had to cut a small drain channel on one side, in the surface of my brand new slab :mad: as I was worried the door might freeze down if water sat there.
JB
/ Concrete Pad Slope #16
Your way off on your angle and your solids wouldn't move at 1%. There is some argument about the slope being too steep and the liquids out running the solids, but a lot of that is from the older type of pipes and not PVC.
You can have your treatment plant as far away as you want, and in most cities, even uphill from the sewage drains. The waste goes to a pump station where it is pumped up to a manhole, where it flows down to the next pump station or to the treatment plant.
Have you ever done sewage lines before? or are you using information that you heard second hand?
Eddie
/ Concrete Pad Slope #17
Eddie
WTF! Not to you Eddie :) I just typed a long response to this and windows decided to run some update without even asking me, and shut down and lost my work.
So anyway wife is screaming to get ready for church, but the short story is I do know a little about the subject and no our main trunk sewer has no pump stations.
Some pics of inside a large storm sewer.
JB.
/ Concrete Pad Slope #18
Around here sewers go down to 1%.
Same here. Any more than that and the water runs to fast leaving the solids.
1/8 per foot is more than enough pitch for an outdoor pad that has an even remotely decent finish job.
/ Concrete Pad Slope #19
I know it's nothing to do with OP's pad but this explains how a sanitary sewer can flow for miles without much slope at all.
The 1% minimum is only for house sewer laterals that are 6 inch. 2% for 4 inch lines under the floor. once it gets into the street the slope requirements go way down. I guess it's due to the volume of push behind it?
See the chart on page 9, A 24" main sewer only needs 1 inch of slope for 100 feet!
http://www.co.rockbridge.va.us/departments/PSA/rules_regs/Section 2.pdf
JB
/ Concrete Pad Slope #20
OK, that makes more sense. I don't think we're talking about the same things with regards to the sewer lines. All I work on is residential remodels, and 2 percent might pass inspection, but it's gonna get me a real close look at everything else to make sure it's perfect.
Eddie
Case-IH P170 (A64912)
2019 JCB 409-T4 WHEEL LOADER (A65056)
2019 JCB 409-T4...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65056)
2019 CATERPILLAR...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2023 CATERPILLAR 920 WHEEL LOADER (A65056)
2023 CATERPILLAR...
