computer low on resources ----what?
/ computer low on resources ----what? #1
livincountry
west central ohio
cub
I have a Dell Dimension 2100 (Celeron) with 128M RAM. I kept getting a message that said "computer is running low on resources, please close some applications" something like that anyway. I thought it was RAM so I purchased another 128M of RAM from Dell. The RAM is recognized but the problem of "low resources" comes up unless I close all but one program at a time. I have cleaned out all the temp directories I can find. I do have a firewall and virus protection running all the time but I thought adding more RAM would fix this.
What the heck does "low resources" mean?
/ computer low on resources ----what? #2
What operating system are you running? I'm told that with each release of Windows they increase the user resource area.. a cynical person might think they deliberately left it small initially so people would feel an incentive to upgrade. /forums/images/graemlins/mad.gif
Adding RAM doesn't seem to help.. I'm not really sure what does help, to be honest. Must be some Windows gurus here who have some ideas.
Maybe one of your programs has a memory leak.. that is, it doesn't release memory it's no longer using?
HTH,
Bob
/ computer low on resources ----what? #4
I use a small, free program called FreeRam ( web page) to free up memory choked by memory leaks, but it doesn't affect system resources. Here's what the FreeRam program says about system resources:
"You may find that your System Resources (found by going to System Properties in Control Panels) is unchanged after FreeRAM XP Pro optimizes your memory. Some users have emailed me about this. Know that System Resources and RAM are two entirely separate, different entities. RAM is used by Windows to load and retrieve data quickly, while the System Resources can be used to store user and graphics information and to reference other memory. FreeRAM XP Pro optimizes your RAM, *not* your System Resources. Therefore System Resources usually remain unchanged after using FreeRAM XP Pro. However, FreeRAM XP Pro is able to monitor System Resources for you, and alert you if they get too low, which can cause problems (eg, freeze or crash).
"Note: Under Windows 95, 98, and ME, System Resources are limited to 2 MB. On Windows NT, 2k, and XP, it can grow and shrink to suit Windows' needs. That's why these operating systems tend to be more stable."
/ computer low on resources ----what? #5
Our IT gurus at work told me to shut my computer down at least once a week to keep this from happening so often. I always shut mine down at home, but at work I just left it running. I now shut it off every Friday evening unless they're going to do maintenance.
Haven't had the problem in months.
/ computer low on resources ----what? #6
If you're running Win 98, you can try troubleshooting to see what (if anything) is eating the system resources.
If you go to START-PROGRAMS-ACCESSORIES-SYSTEM TOOLS, you'll see the Resource Meter application (or, you can type (or copy and paste) the following:
RSRCMTR.EXE
into your START-RUN window.
This application (it's on the Windows CD-ROM if not installed) monitors the usage of your system's RAM, CPU, etc.
/ computer low on resources ----what? #7
If you will run Windows XP, you won't have the problem as they don't use the resources with it. So you won't have it anymore. I aways had it to, when I was using 98, or ME. but not with XP, that is why you don't have the crashes anymore either like with 98 or ME.
Thank you for all the responses. Great insight!
I am running ME. I have (or had) the opportunity to upgrade to XP when I purchased it ~ 2 years ago. I'll have to see if this has expired or not. Thanks again!
Trailertrash, the Kim Komando site is just what the doctor ordered.
Clark county? I live in Clark County. Just finished our week at the fair. The kids had hogs. Glad to see them go...Hogs not the kids! /forums/images/graemlins/grin.gif
Thanks again.
Tony
/ computer low on resources ----what? #10
livincountry:
I live just outside S. Charleston, it truly is a small world sometimes.We went to the fair twice , mud drags, and tractor pulls, young daughter child was there all week.Those boys(pullers) have some very, very expensive toys considering they only get to run about 5 mins. a week.I hope the k k site helps she has a lot of good info on there and a lot of free stuff too.
/ computer low on resources ----what? #11
</font><font color="blue" class="small">( I am running ME.)</font>
Just on the light side, there's a company around here with an ad on the radio... something like "We support all versions of Mac, and all version of Windows except ME." Maybe Win 2000 Pro would be a good way to go if you want to avoid XP.
As to the shutting down periodically, yeah, I do that now too. Every Monday morning, I reboot the machine. Usually don't have problems unless I forgot.
Bob
/ computer low on resources ----what? #12
I have ran just about them all, I think the first one was 3.1, if I remember right. 95, 98, ME, 2000 Pro, now XP Pro. I like the XP Pro best of them all. It takes a little getting use to, but after you do, its worth it, for lack of crashes and being stable. /forums/images/graemlins/grin.gif
Well....we're at the other end of the county. Just west of North Hampton.
Thanks again,
Tony
PALLET OF TRASH PUMPS (A68842)
PALLET OF TRASH...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
