computer/internet stalls
/ computer/internet stalls #21
<font color=blue>Just for grins, have you used the Windows Update function lately? It can be a bit tedious (what with the weekly bugs that MS fesses up to) but some of the patches actually have been known to fix things (usually).</font color=blue>
And sometimes weird things happen. After a Windows Update last week, it wiped out my MSN Messenger; had to download, re-install, etc. and start over with it./w3tcompact/icons/frown.gif
So far, I haven't found any problem with the updates it did this morning./w3tcompact/icons/laugh.gif
/ computer/internet stalls #22
<font color=blue>I couldn't run my computers without Norton System Works.</font color=blue>
Me, too.
/ computer/internet stalls #23
I'm not sure at this point if you are seeing normal Internet congestion or if your machine is loaded with an attack-bot or two.
Here is a good story everybody should read.. it's the classic story Steve Gibson wrote after his site was attacked. It explains what the script-kiddies out there are doing these days with any machine they can find that isn't protected. In your case, your bandwidth may be being eaten up from time to time when it participates in a denial of service attack.
<A target="_blank" HREF=http://grc.com/dos/grcdos.htm>http://grc.com/dos/grcdos.htm</A>
At one point this was the most popular page on the Internet in terms of hits, right after it came out (or so I'm told.)
Best,
Bob
/ computer/internet stalls #24
Bob:
Thanks for the link. What a fascinating and educational story - and very well written. As I read it, like a good book, I "couldn't put it down"!
It seems we're all vulnerable. Even though the target of one of those denial of service attacks is probably some large web site, if we're an unwitting participant our measly dial-up bandwidth could easily be eaten up resulting in denial of our service.
Scary /w3tcompact/icons/frown.gif
/ computer/internet stalls #25
Boy, that stuff is scary! I would recommend that anybody using the Internet use a router, even if you're using only one machine.
/ computer/internet stalls #26
<font color=blue>It seems we're all vulnerable. Even though the target of one of those denial of service attacks is probably some large web site, if we're an unwitting participant our measly dial-up bandwidth could easily be eaten up resulting in denial of our service.</font color=blue>
Precisely! Your machine could be spending most of its resources attacking some site and you would know nothing of it at all, except you'd see things slow down quite a bit. I'm not saying that's what's happening, but it's certainly a possibility.
Also, the chances of identity theft are considerable. People really need to understand some of these issues nowadays, in the age of the "13 year old Internet Terrorist". /w3tcompact/icons/hmm.gif
Glad you liked the read! Steve is a pretty good guy...
Bob
/ computer/internet stalls #27
<font color=blue>I would recommend that anybody using the Internet use a router, even if you're using only one machine. </font color=blue>
But don't forget, you also need to be able to tell if an outgoing connection is being attempted by some program on your machine which has no business doing so. The only way I know of to do that easily is to run a software firewall which monitors both incoming and outgoing connections. A router will know nothing about what program is sending data out.. all it sees is a bunch of packets going out.
Bob
/ computer/internet stalls #28
Trev,
That was fascinating. Reading it all blew away my entire morning but it was well worth it. Thanks for posting that link.
/ computer/internet stalls #29
<font color=blue> I would recommend that anybody using the Internet use a router, even if you're using only one machine. </font color=blue>
I concur, just on the basis of being an easy way to set up a home network. A router, by itself, however, does not provide any protection. All a router does is route packets (to/from your network or PC, to/from the Internet).
Unless things have changed recently, for most of these home routers (and this is also esp. true with business routers), they include firewall intelligence, but do not have any firewall enabled, by default. You have to read the manual and go into the command-line interface (or web interface, usually provided), to enable your protection. Firewalling at a router involves packet inspection, and deciding whether to accept or reject that packet based on defined rules. Home routers typically provide some default firewall settings you can choose from (minimum, moderate, maximum), but you have to make the choice and enable it.
I loaded ADAWARE. It found 94 suspect files, all cookie related. I removed those, rebooted, and am trying by starting here. I also cleaned out the temporary internet files. I think it said there was like 2000 files... maybe I should do that more often...
I do not note any internet change, but I just logged back in a moment ago... We'll see. If nothing else, it was good to clean the system up a bit.
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
121A (A63745)
121A (A63745)
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
