Compression Tester Not Working
/ Compression Tester Not Working #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi All,
Got a bit of a dome scratcher. I have a basic compression tester that has always worked well on my briggs/techumseh rebuilds, but went to use it this morning and it won't read at all. Then I tried it on my Stihl MS 250 saw and it immediately started to read when I pulled the cord. I tried it on several small engines and it just won't read. Never had that problem before. I did change the needle valve in the line, but still no readings. Anyone have any suggestions? Thanks!
/ Compression Tester Not Working #3
Seems like that I read somewhere, that the needle valve is specific for compression testers.........not your ordinary tire valve needle gizmo.
Cheers,
Mike
/ Compression Tester Not Working #5
do those engines have a decompression valve? dont know if that would make a difference but maybe.
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2022 EZ-GO ELITE...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
