Oil & Fuel "compression" start for a diesel
   / "compression" start for a diesel #1
simonmeridew
Northeastern Vermont
Kubota L4400
Just a theoretical question: is there any reason a diesel engine can't be started using a compression start-- turning on the key, putting the gearshift in 4th gear and popping the clutch? Of course a HST won't do it.
simonmeridew
   / "compression" start for a diesel #2
It would help if it was moving at the time you 'popped' the clutch.
   / "compression" start for a diesel #3
Glow plugs,if applicable,would help it start easier on a push start.
   / "compression" start for a diesel #4
Theoretically, it'll start.
Practically, it depends on tractor weight (tire slippage), gear ratio (engine spin speed), grade, and engine temperature. Depending on temperature, distance could become a factor...:D
   / "compression" start for a diesel #5
it can be done for a diesel, at one time my dad ran diesel VW rabbits and Jettas, after working on them instead of wearing out a battery to get them primed (the only fuel pump was in the injection pump) we would push it out of the shop and to the "big hill" and he would take it down, put it in gear and pop the clutch... they generally started by the time they got to the bottom.
now that might get exiting on a tractor... but YMMV.
Aaron Z
   / "compression" start for a diesel #6
It works fine on diesel tractors. The trick is to put it in the highest gear you have and to pop the clutch while the tractor is moving slowly. Too fast and the tires will just skid.
rScotty
   / "compression" start for a diesel #7
My L3600's starter solenoid stopped working earlier this summer - we could get it rolling by hand in the driveway and pop the clutch in high gear - lit up right away.
thanks for the replies!
I'm most interested in making sure it's ok for the tractor--oil pressure issues on startup, injector pressures etc.
simonmeridew
   / "compression" start for a diesel #9
simonmeridew
Turning the engine is the same if from an electric motor, a pony (gas engine) or rolling down a hill. You need to rotate the diesel engine to get it to run. I remember rolling a 3020 John Deere down a hill and popping the clutch when I was a kid to see if it would start. It did start very easily. However it was warmed up from running about 1 hour so the lack of using glow plugs was not an issue. It does not make any difference how you get the diesel to turn. You just need to get it to turn to start. If you had a totally dead battery (or no battery) one of the new diesels with a an electric fuel shut off would not start because of no fuel delivery.
   / "compression" start for a diesel #10
Ain't Auto ignition great Dick!!!!!!! I've done the same thing with my L2600 dead batteries to light her off.
2008 Volkswagen EOS Luxury (A50324)
2008 Volkswagen...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
