Compactor we built for work.
/ Compactor we built for work. #1
Taylortractornut
Elite Member
Iuka Mississippi USA
3550 Fard Backhoe and a 1948 Farmall Cub,
I thought yall might like to see a couple pics of the compactor we built for the Landfill I work at. When Tiffins bought the landfill we got new types of rubbish that he D5B wouldnt compact as well. When we ran out of space in one cell way too early wer talkedthem into letting us get a compactor. We run a small working face with not alot of waste comming in so a larger compactor like a 816 Cato which is there smallest was out of the question. Plus a used one sells easy for 60 K. I remebered whe I as little that Dad told me about a Cat skidder wit hDirt compactor wheels working near them on HWY 45. He didnt get to see it up close Then we found a few in some oldleaflets I had. They came either with Landfill wheels or soil wheels. I found out most companies in the compactor business used there wheel loader and skidder lines at first then the wheel dozer lines and special machinery. Cat was the most avaliable ones that were converted mainly the 518. We checked over the intrnet and found that They went in the high 30's to a good one almost 50k. And a set of used Caron wheels was about 45000 and about 20000 for a used Skidder. Dad and I got together and remebered the neighbor had an old 518 Feller buncher that was based on a 518. That was a better choice for a conversion as they didnt have the strain and wear in them from pulling logs all day. They also didnt get alot of use because when it was new the biggest hard wood it would handle was 18 inches and 24 inches in soft wood. We bought it fo 14 000, but the controls all faced backwards and it had a low lift loader boom where the grapple and winch went. He also threw in a large semi Ublade of a 290M wheel dozer scraper tractor. While we were picking it up we were thinking about the wheels and I came up with taking the front ends off of 2 Hyster rollers to make the 4 wheels. The front drums on the older rollers were split to make it easier to steer on the fresh pavement without scarring it. He los through them in on the deal for the tires off the machine back.
We carried the machine over to William Davis's shop and talked about it He helped us cut the rollers up and used his forklift to move the blade out of the woods. William pulled off most of the old hoses and the felling head and rebushed the lift pivots. i carried the steam cleaner there and wer gave the belly pans a washing out. William cut the Centers out of the roller wheels and the back bead off the skidder rims. The welded the rims into each drum. The were exactly a foot smaller than the original tires on the machine so it worked out when we added the six inch spikes. Dad and I talked about changing the controls aroun to make it a Narmal skidder but the that you have been extra work and we also wanted the extra weight of the arms. As we thought of it we realized one of the problems with the Dozer was that on some of the loads we got was light and the dozer blade would just scoot it along as it couldnt break it up only cating it 3 ffet off the ground. So we had william cut the brackets off the shear head and mount them to the 290 M blade after he cleaned it up and added a tall spill guard. That gave us a 6 to 7 foot blade lift hieght. The blade was the same weight as the shear head at 6500 pounds so we came out great on that. Since we get a mix of rubbish we made our front wheels spikes and the back wheels Chopper feet. It works super great grindign up all the rubbish with a 10 to 1 compaction rate. Plus saved wear on the dozer. Ill try to find a few action shots later, and a few of the just finished shots we have of it.
http://i471.photobucket.com/albums/rr78/tumblebugtaylor/518compactorconversion.jpg
LBrown59 We built this one for the private landfill we run, Theres actually alot of them this size as Cat did sell a number of these conversions in both soil and landfill. I think 98 Cat took them off because they had alot out on the market that filled the small landfills. We only get about 7 40 yard loads a day and when its booming we get up to 18. Our working face is usually only 30 to 40 feet wide, and about 25 to 30 feet long thus a larger machine would be cumbersome. The pic with the blade up is on a base of 3 inch rock on top of virgin clay and the 3 inch rock is covred in 4 inches of crusher run wetted and compacted why its standing on its tippy toes. Thats a rough 50 foot drive lol. In about 5 passes it grinds the wood waste with is adlerwood strips and black from the cabinet shop and pallets up into about 3 inch chips. The standard skidder conversion had a built up blade and the winch and grappel removed. Then it had precast weght on the back. ours has about twice the weigh of the boxx be cause of the arms and the blade which alone th ebale is 6000 pounds. I think Volvo still offers a wheel loader conversion, and I know Dressta Still make there version of a 515 Dresser loader with a landfill conversion. I know that Kaelble and Massey Ferguson did the same. The ones at mos land fills a Cat 826 and 36 rigs. Our county has a dead 816 which is an 815 wheel dozer or com pacto but it has the landfill package.
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2015 Deere 210G (A64126)
2015 Deere 210G...
