MessickFarmEqu
Super Member
what constitutes a tractor in 3rd world countries can also be darn close to a walk behind rototiller. People in near poverty are not buying the same kinda stuff we do.
I'm not sure how you could ever get an accurate reading. With everybody making tractors for everybody else now days. For example LS has there real numbers but then they build tractors for new Holland so do you count LS twice or do you not count LS & only count new Holland for the ones they sell to them or do you not count the new Holland and only count the LS???
What about the Yanmar & DaeDong (kioti)made John Deeres do we take them out of the mix give the credit to Yanmar &DaeDong. Probably should. I believe T YM makes a fairly large share of Mahendra tractors also. So as far as I'm concerned the big boys can say all they want about numbers. But I don't see how they can use that to put down the smaller companies that they're buying the tractors from, just doesn't make sense. Someone please correct me if I'm wrong but I believe Kubota is on top if you only count compact and subcompact and then only the tractors they produce themselves.
All good points. For me, it just feels better knowing the tractor is entirely made by the company name on the hood.
I agree^^^^
Does Kubota make all their own tractors? That is what I have heard on this forum and if true is a good thing imo.
I would expect all of them have at least some outside vendors for small assemblies and that still provides jobs for the masses.
I won't say Kubota makes all their own. That would open a heated discussion nitpicking details. I'll say Kubota makes their own powertrain components and hydraulic systems. I would assume they would outsource things such as alternators, starters, radiators, tires/wheels, etc.
My old Ford (1984) is made the same way.
My little JD2210 on the other hand is outsourced. I've not ran across any powertrain component that is stamped JD.
I would agree that the Kubota and Ford were in keeping with idea of being built in house. The Deere you speak of is simply rebadged with their name. As long as the seller makes good on delivery and service over time all is good.
As an example I would put more faith in Goodyear, Michelin and Firestone tires than in Kubota, Ford or Deere branded tires. Some things are better built by others.
There are 1.25 BILLION people in India.
68% India's population is rural.
India has a huge number of small farms.
India, india, INDIA. Mahindra, mahindra, MAHINDRA.
