Compact Tractor Sweeper
/ Compact Tractor Sweeper #2
I've seen those on golf courses. They must be expensive. Did you find one used
I did purchase the CP48 from a golf course. It was lightly used as they had bigger equipment. The pulverizer was removed along with the back half of the unit. I added a deflector plate, the collection box and hydraulic cylinder. In fact in a couple of hours you could switch it back to a pulverizer. As I understand those were not cheap units and it's construction shows it. I got a deal that was too good to pass up for this project.
just a couple of short operational videos. Grass is pretty thin this time of year.
/ Compact Tractor Sweeper #7
Looking like that rig works real well for you.
Thanks for the video's. :thumbsup:
/ Compact Tractor Sweeper #8
How do you think it would handle heavy leaves? Can you post a picture of the actual sweeper part?
/ Compact Tractor Sweeper #9
Yes they are used by golf courses. The CP48 is a core pulverizer. It is designed to pick up the cores after the greens are aerated then pulverize them. They are usually used in tandem with a TC125 which is the collection unit that follows up and actually does the sweeping.
Looks like you did a nice adaption for clippings and leaf collection. Keep us updated on how it works!!
skunk that is exactly what I did. I was tired of working with what is out there and wanted something bigger to save time. This set up saves a lot of time as I can run the sweeper and deck to clean up. It's way overpowered for sweeping. For grass I'm never above half throttle w that 12hp.
4570Man, We'll find out but I think it will do great job on leaves up to a point. More than enough hp and raising the front skirt should do it. If I lower the brushes to contact the ground this thing will take grass and all, down to bare ground, so those wet leaves flat on the ground might be a problem. It was designed to pick up cores so that should give you an idea. In grass the thicker the better.
/ Compact Tractor Sweeper #11
Will it shred leafs, or just pick them up?
Don't know yet as I just completed this mod in July. We'll find out.
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
20' CONNEX BOX (A65643)
20' CONNEX BOX...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
Case IH 1020 15' Grain Platform (A66408)
Case IH 1020 15'...
