Compact Tractor Sweeper
/ Compact Tractor Sweeper #2
I've seen those on golf courses. They must be expensive. Did you find one used
I did purchase the CP48 from a golf course. It was lightly used as they had bigger equipment. The pulverizer was removed along with the back half of the unit. I added a deflector plate, the collection box and hydraulic cylinder. In fact in a couple of hours you could switch it back to a pulverizer. As I understand those were not cheap units and it's construction shows it. I got a deal that was too good to pass up for this project.
just a couple of short operational videos. Grass is pretty thin this time of year.
/ Compact Tractor Sweeper #7
Looking like that rig works real well for you.
Thanks for the video's. :thumbsup:
/ Compact Tractor Sweeper #8
How do you think it would handle heavy leaves? Can you post a picture of the actual sweeper part?
/ Compact Tractor Sweeper #9
Yes they are used by golf courses. The CP48 is a core pulverizer. It is designed to pick up the cores after the greens are aerated then pulverize them. They are usually used in tandem with a TC125 which is the collection unit that follows up and actually does the sweeping.
Looks like you did a nice adaption for clippings and leaf collection. Keep us updated on how it works!!
skunk that is exactly what I did. I was tired of working with what is out there and wanted something bigger to save time. This set up saves a lot of time as I can run the sweeper and deck to clean up. It's way overpowered for sweeping. For grass I'm never above half throttle w that 12hp.
4570Man, We'll find out but I think it will do great job on leaves up to a point. More than enough hp and raising the front skirt should do it. If I lower the brushes to contact the ground this thing will take grass and all, down to bare ground, so those wet leaves flat on the ground might be a problem. It was designed to pick up cores so that should give you an idea. In grass the thicker the better.
/ Compact Tractor Sweeper #11
Will it shred leafs, or just pick them up?
Don't know yet as I just completed this mod in July. We'll find out.
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
CATERPILLAR D4H CRAWLER DOZER (A64277)
CATERPILLAR D4H...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
