Compact telehandler
/ Compact telehandler #231
It came that way. It is needed with the front castor wheel.
But I can also curl up and keep the front wheel up off of the ground if necessary :thumbsup:.
That's what I like about my brush cutter on the FEL arms of my PT425. The cutter has two casters out front and two fixed wheels on the back. I can leave the FEL arms in float and the deck will follow the terrain, or I can lift it up to 4' off the ground and bring it's weight down on a shrub or bush to smash it down before cutting it, or I can cut almost vertically. It's also extremely nice to cut everything down before driving through it. Extremely nice! :thumbsup:
/ Compact telehandler #232
This year we started feeding the bales in the horse barn, keeping it dry. Have been setting them in flat with the bale spear. This time I wanted to set it on end, so used the grapple on the 5x6 bale:
/ Compact telehandler #233
Re: Compact telehandler Pulling the rope!!
Haven't done anything new or different recently with the V417, so here is a project from 2017.
These oaks are too close to the trailer barn, the branches grow down onto the roof. Got tired of trimming back every year, so decided to try something I had never done before. No room to push them over like I usually do, so hooked up a long rope to the Gorilla Grapple.
It broke :(.
Hooked up the other one and retracted the boom some to get the side view picture.
Retracted all the way and it also broke :(.
Hooked a chain to each trunk and drug them out to the driveway.
Picked up one and took to the burn pile.
Picked up the other one and dropped it on the burn pile.
Mission accomplished :thumbsup:.
/ Compact telehandler #234
This is a project I should have done years ago. 8 willow trees grew up at the pond overflow structure.
From the other side:
Pushed on the closest one, it broke:
Pushed on the next one, it went over:
Grabbed the roots and pulled it up:
Grabbed the trunk of the first one:
The first two and a little broken one on the pile:
/ Compact telehandler #235
Went back the next day with the stump bucket on and uprooted the rest:
#4 to the pile:
#5:
#6:
#7:
#8:
8 on the pile:
/ Compact telehandler #236
Went back the next day with the stump bucket on and uprooted the rest...
Hi XFaxMan!
I had a usage question-
When using the mower, can you reach into areas by extending the boom?
We have a pretty steep hill at the back of our house, and the ability to mow it by using the boom might the straw that breaks the dam, and convinces SWMBO to agree to buying a [used] CTH. [Please pardon the mixed metaphors.]
She already likes the idea of having one as a man-lift to keep me [mostly] off of ladders, and the ability to extend the boom and grapple, and pull downed limbs and trees out of the woods, so this might just seal the deal.
Thanks in advance for your assistance, and is retrospect for posting all the great pictures and information about these awesome machines.
Thomas
[PhysAssist]
/ Compact telehandler #237
Hi XFaxMan!
Thanks in advance for your assistance, and in retrospect for posting all the great pictures and information about these awesome machines.
Thomas
[PhysAssist]
You're welcome and thanks, just trying to pay it forward.
Yes, just be careful not to get the back of the mower higher than the front where it could throw debris at the windshield :eek:.
Here it is with the boom almost fully extended, mowing over a silted in creek at the edge of the pond where we used to live:
This is what happens if you drive into silt:
The right side was on dry ground, you can see the tire tracks over there. And I was standing on the dry top surface of the silt taking the picture :eek:.
/ Compact telehandler #238
Same pond three years earlier. Hired a dozer to knock down the willow trees at the edge of the pond:
He got into the silt :eek::
He brought his other dozer over:
/ Compact telehandler #239
A little job for the big grapple. A pile of small dead branches:
Raked over to the bottom tines with the dual lids:
Picked up and curled up:
Put it on the burn pile:
/ Compact telehandler #240
A Little Pushover Job For The Compact Telehandler. Part One
Tried to push over this oak:
Didn't push, so moved up higher to get more leverage:
More leverage split the trunk:
Moved to the other side and pushed:
Got some movement of the root ball:
Note the crack in the ground:
Pushed more and felt roots breaking:
Pushed out to maximum boom extension:
Didn't go over, so I lowered the boom. Note the left front tire is off the concrete:
It has a lot of roots:
This is as far over as it will go:
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
Freightliner Columbia (A61307)
Freightliner...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A60736)
2021 QUALITY...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2002 Crosley 14ft. T/A Equipment Trailer (A59230)
2002 Crosley 14ft...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
