Compact articulated loaders
   / Compact articulated loaders #11
I have a Kubota R510 with Cab and backhoe. It is an awesome machine! I could go on and on about it's many attributes. I wish I had a newer articulated loader, like a Case or JD, but would really miss the backhoe. View attachment 355212 That is a full lift of roof sheating.
Nice equipment! I haven't even seen a backhoe/ loader combo like that before. All tires are the same size. And I want to know how to post pictures as well.
   / Compact articulated loaders #13
That is the beauty of wheel loaders. The four equal sized tires. Solid axles without ball joints or U joints on the axles for steering. The rear wheels track the front perfectly. Backward is no different from forward in traction or geometry. Very easy on turf. Very close turning radius.
Wheel loaders are notoriously unstable though, when handling a load on uneven ground! I've had one front wheel in the air many a time! You just have to keep your cool and know what to do.
My particular machine is a bit of a Rube Goldburg as the selling dealer stated. It has the larger (Bradco) hoe on the back which is just a bit much for this machine. The normal hoe is the smaller fold up one. I think reach is absolutely everything in a hoe and would probably not want to have to live with the smaller one, but despite them loading the front tires almost full with Calcium, it is still rear heavy! The approach angle is also quite miserable!
The top speed of this machine, which has two speeds, is too slow to want to travel any great distance.
I switched the coupler to a hydraulically controlled skid steer type. I don't need side shift forks as the machine does this on it's own with the articulation, but I did attach a scrapped fork carrier that has hydraulically adjustable forks and that is one slick affair. You can also pinch things and pick them up, within reason
   / Compact articulated loaders #14
There's one (Kubota) at the local landscape yard ... and the city I work for has one in their public works garage (also Kubota I believe).
Just snapped a pic...
   / Compact articulated loaders #15
   / Compact articulated loaders #16
Thanks for your reactions, much appreciated. To give more info on myself, I am intending to start offering wheelloaders from 'Giant' to the US this year. They offer wide range of types and implements and can offer you the machine you want. Need a bobcat attachment bracket? no problem.
Here's their site: Tobroco Machines the wheelloader specialist! - Giant Tobroco Machines
   / Compact articulated loaders #19
We have a Kubota R520 with the side shift hoe and in my opinion, it is best for planting jobs. It will pick up 5000lbs and has a bucket pin height of 11 feet when fully raised, which for smallish wheel loader is excellent, especially if you need to load material into a tri axel dump. The hoe digs well but I never use it for more than digging tree holes or very short trenches, it's annoying to relocate when trenching due to its layout and it is also very hard on the center swivel/ pivot joint.
No idea, but I want one! Very cool. How do they compare to compact tractors in loader capacity and lift height?
A 45hp wheelloader I want to start offering in the US: tippingload in straight position, without extra couterweights, is 1000/1100 kg.
Lift height will be 3 meters.
you can check out more technical data on different types here: Leaflets English - Downloads - Giant Tobroco Machines
kind regards
chris
New Holland WorkMaster 37 (A53317)
New Holland...
Kubota SVL75-3 (A57148)
Kubota SVL75-3...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
MISC TIRES (A54757)
MISC TIRES (A54757)
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
