Comments on Trailer Brake Controllers?
/ Comments on Trailer Brake Controllers? #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
What do you all think about the Tekonsha <font color="blue">Prodigy</font> controller? I've been reading other threads that mention it. It looks from the information of this web page that they address some concerns that have been expressed about operating on hilly terrain, or backing up.
I've also looked at the <font color="blue">Jordan Ultima</font> which has been recommended, but I wonder about the amount of braking applied to the trailer being determined by the amount of tow vehicle brake pedal travel. Will it accommodate for changes in the condition of the brakes in the tow vehicle which might require more brake pedal travel to acheive the desired braking?
/ Comments on Trailer Brake Controllers? #2
I have had the Prodigy for a several years now. It has been a great controller. Here is a thread on them. Click Here
There have been a couple of recent threads where the Prodigy has been discussed also. For ease of installation and operation you cannot beat the Prodigy.
/ Comments on Trailer Brake Controllers? #3
I look at it this way. There are perhaps better controllers out there -- there are less expensive controllers out there...
But, the Prodigy is likely the biggest selling controller out there -- for a reason...
/ Comments on Trailer Brake Controllers? #4
I have been using the Jordan Ultima for about 1 1/2 years. I got it after the Tekonsha Voyager unit I had stopped working while towing my tractor /forums/images/graemlins/shocked.gif
All I can say is, WOW /forums/images/graemlins/grin.gif It is so smooth! You hardly know your towing a trailer.
There are no high-tech electronics to blow up, just a simple rheostat that increases voltage in proportion to the brake pedal position. It reminds me of the old controllers we had at work work years ago that were tapped into the hydraulic brake lines.
The AMP gauge is a nice feature, you quickly learn what your trailer reads at different loads so you can change the braking on the fly. And if you loose a brake due to wiring or a bad magnet, you will see the decrease in amp draw on the gauge. It is also made in the USA, and has a real nice metal case that can be mounted any way you want; sideways, backwards, upside down, whatever....it does not care!
And I think for the $119.00 delivered it is a real bargain /forums/images/graemlins/grin.gif
/ Comments on Trailer Brake Controllers? #5
I like the Prodigy brake controller so well that when I traded my Ford F350 in on a Chevy Silverado....I insisted they install the Prodigy on the Chevy. They did...it works great, and it's easy to use.
/ Comments on Trailer Brake Controllers? #6
This is like asking which is better: Stihl or Husky?
I've got a Prodigy. The Jordan is probably a better controller, but he Prodigy does all I need it to do. I would buy another.
/ Comments on Trailer Brake Controllers? #7
/forums/images/graemlins/grin.gif cp1969 good point.
I've a Prodigy and a Stihl.
The best? Just what I am real happy with, but can't say they are the best, but wouldn't buy anything else if doing it over again. /forums/images/graemlins/wink.gif
/ Comments on Trailer Brake Controllers? #8
I have a Tekonosha and a Husqvarna 385....
/ Comments on Trailer Brake Controllers? #9
Brakesmart is sposta be the leader of the pack.
I've got a Jordan and a Stihl, the Stihl doesn't stop the trailer worth a darn though. /forums/images/graemlins/smile.gif
/ Comments on Trailer Brake Controllers? #10
Prodigy and a Stihl .... can't comment on the Prodigy since I haven't managed to get around to hooking it up .... but the Stihl has been going strong for about 25 years ..... /forums/images/graemlins/grin.gif
/ Comments on Trailer Brake Controllers? #11
I've had a Prodigy and a Voyager and a Jordan and I think the best of all is the Jordan...by far. It's got the best feel and no weird electronics to get flaky on you in certain situations like wet downhill conditions. I tow a pretty heavy travel trailer with my 85 F250 and the Jordan has eased my mind. Hooking it up isn't as easy as just plugging in some wires however. It does take a little more effort. Good luck.
/ Comments on Trailer Brake Controllers? #12
I have a Husky, a Stihl, and a Jordan Ultima. I liked the fact if for some reason the tow vehicle would lose its braking system (engine die, ABS gremlins etc..) I would still have proportional braking. I think the Prodigy is also a very nice product, but haven't used one, you probably will be happy with either one.
/ Comments on Trailer Brake Controllers? #13
I had a Jordan on a 3500 I recently sold and it worked great, I have a POS draw tite activator in my Pete 385 that you can't tell if it's working or not mainly due to the truck weighing in at 17,000lbs and my tractor and trailer may weigh in at 5,000lbs, I just have it to help stabilize the trailer under braking.
/ Comments on Trailer Brake Controllers? #14
When I was shopping for a controller, the only controller I found to be better than the Tekonsha Prodigy is the Draw Tite Intella Stop. Its exactly the same controller, made by the same company and all, but it was slightly cheaper. I got it for about $80+$6 shipping. the install went well and easy but I havent had a chance to use it yet.
/ Comments on Trailer Brake Controllers? #15
</font><font color="blue" class="small">( When I was shopping for a controller, the only controller I found to be better than the Tekonsha Prodigy is the Draw Tite Intella Stop. Its exactly the same controller, made by the same company and all, but it was slightly cheaper. I got it for about $80+$6 shipping. the install went well and easy but I havent had a chance to use it yet. )</font>
I've been using that same Draw-Tite controller for the better part of 4 years now. ZERO problems, and good, smooth operation. No problem with recommending it to anyone.
I use it on a Dodge 2500 4WD diesel, pulling a 30'/14,000 GVWR gooseneck that usually has a full load. Stops good, and no abnormalities with the brakes.
/ Comments on Trailer Brake Controllers? #16
If you can get a Brakesmart controller, they are the best on the market at the moment. That being said, a Prodigy is a good controller with the Jordan being just a bit better.
/ Comments on Trailer Brake Controllers? #17
I used a Tekonsha Prodigy in my F-150 for three years with great results. It got me out of trouble a few times when I had my trailer load unbalanced /forums/images/graemlins/shocked.gif. I've learned not to do that anymore. I've not had the pleasure to use the others referred to in this thread so my opinion is for the Prodigy only.
The only thing I found better is my new F-250 with integrated controller. It ROCKS! That is the one reason I bought the Ford (that, and it was the cheapest /forums/images/graemlins/smirk.gif). I have to keep looking back to see if the trailer is still attached cuz stopping is smooth as silk if I'm dragging the Bobcat or just a pile of junk.
Oh yeah, I've got a Stihl and a Husky. Husky cuts faster but the Stihl starts first.
/ Comments on Trailer Brake Controllers? #18
I've used the Tekonsha Voyager on my '93 Nissan 4x4, in my Ford LN600 dump truck and my 2000 F250 Super Duty and have had no failures and good braking. I haul my tractor several times a week commercially - gross trailer weight is usually 10k - 11k and it works great. I also have an Anderson dump trailer 6 ton gross and it performs just fine too at all varying loads. The adjustments on the Voyager are touchy - not the easiest to adjust while going down the road, but the controller is reasonably forgiving and I haven't had any problems. Of course when I install one I solder all connections and use heat shrink etc. - and looming to protect wires etc. Of course properly serviced brakes on your trailer(s) make a difference too. My F250 had the factory wiring and only had to buy the harness & relays for that install.
/ Comments on Trailer Brake Controllers? #19
Stihl or Husky... It depends on the model. For the arborist saws used in tree limbing, my opinion is that there is no saw that is comparable to the Stihl. For the bigger saws, it gets arguable quickly. Both have many merits. I have the Prodigy brake controller. It works fine. When I sell my truck, it will come out and go in my new truck.
/ Comments on Trailer Brake Controllers? #20
Draw-tite activator 2 and a Stihl. Draw-tite really stands behind their product, I had a problem and they sent a new one out asap- no charge, even free shipping!
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
