Chipper Comments on Salsco 600 PTO chipper
/ Comments on Salsco 600 PTO chipper #21
Larry
One big difference with the Walstein unit is it is direct drive. Sounds good but at 540 RPM in many cases it is more likely to clog. Units like the Salco, Valby and Bearcat (woods) have a pulley to speed up the disc to a 1000 rpm or so.
Chipperman
/ Comments on Salsco 600 PTO chipper #22
GregJ,
Which Bearcat model do you have (70554)? Does it have the 2 speed fan?
/ Comments on Salsco 600 PTO chipper #23
PKS,
I have the 70554 with no exhaust fan/chute. I have heard that it has a problem with clogging.... could be just a rumor, but I was stretching my budget anyway to get it and this sounded like an opportunity to save some money. Actually I am glad I don't have it. I welcome the break in the action to move the chips with my loader every now and then.
Greg
/ Comments on Salsco 600 PTO chipper #24
Where did you hear that "blower rumor"? That's interesting because I went to the Bearcat web site and read a bulletin board thread about the clogging issue.
Apparently the blower housing position causes chips to snag inside. A finer shredder screen seems to help some. But it sounded like the whole problem might be averted if the blower were set to its high speed for a short period to clean things out.
The 70554 seemed like it might fit my needs. What size tractor do you use to drive it? I have a B2400 with 18 hp at the pto.
/ Comments on Salsco 600 PTO chipper #25
I have a B7500, so you will have about 2 more PTO HP than I do. Mine seems to have plenty of power, although I can bog it down with a large enough log. I just cut the larger logs into shorter lengths and then there is no problem. The rumor about the clogging issue was actually from a salesperson.
Greg
/ Comments on Salsco 600 PTO chipper #26
Dave, how do you like the 8hp BCS, I have a 10hp 730 BCS that i bought new in '87, I got the tiller and the 40 in mower and sulky. it's ok mowing on flat ground but not too good on uneven lawn, although it is an excellent tiller since it has a differential that makes for easy turns at the end, and the tine speed is faster than the troybilt i used before. I thought about a chipper but didn't know if i had enough hp, don't know if the newer impliments would work with mine. thanks for the link to their site, I'd lost track of them.
/ Comments on Salsco 600 PTO chipper #27
say art, if you sell these maybe let me know how to get ahold of you (or e-mail me at rberger@verizon.net) because i'd like to buy one and i live in callicoon center (near liberty) maybe not too far from you to buy goosen and tow it home.
/ Comments on Salsco 600 PTO chipper #28
Hmm. This is a 4th one that's in the approximately $1500 range. This one looks very much like the chipper-only DR unit for this price. You can also get the Jinma and a MacKissic. Think the MacKissic is the only one in this price range that is a chipper/shredder. The TPH-122 is what I have. I paid about $1600 for it from a JD dealer, but you can get it for $100+ less from Northern Tool (possibly without the PTO shaft). This is what I've read from other TBNers.
I like both the chipper and shredder and would not be happy without the big chute to do small stuff and leaves. I save lots of mulch money by "stealing" leaves that town people leave at the curb and shredding the leaves with the Mac. Did probably about 100 or so bagfuls last fall and just stole 2 truckloads this afternoon. You can't do this with a chipper-only. Also, you'd be lopping or hand pruning a lot of small stuff to collapse it into a small enough bundle to get it into the chipper feed. With the Mac (and on my old TroyBilt) you just drop the small stuff, often multi-branched, etc. into the bigger hopper, and it sucks it in (most of the time; sometimes you have to diddle with it, but at least you don't have to hand prune it into smaller pieces to fit into the chipper chute).
I had a shredder-only MacKissic that ran on my 12 hp Gravely. Missed having the chipper. It was better for leaves than my TroyBilt though. So, that was about it was good for.
The TPH-122 is a good combo unit.
An acquantaince of mine recently bought a Jinma, all 800# worth of it, AFTER he got it out of its iron crate that it came in and assembled it, etc. It's the most capable of the $1500 units, as it'll take up to 6" limbs. It's a chipper only unit. The blades do come through-bolted with nuts on the back like the chipper blades are attached on the old TroyBilt Tomahawk. The allen-screw-only attachment of the chipper blade on the Mac is NOT a good design. I stripped out one of the 3 screws my first time removing them. Now, I only put the screws back with the BLUE thread stuff, not the red that they probably used initially, and I use a real allen wrench that fits on my socket handle, not one of those icky little right angle things.
A shredder assembly, like is on the Mac and on my old TroyBilt Tomahawk has 4 shafts with 4 hammers on each shaft held in place by some very hard steel hammers that rotate about the shafts. These hammers will smash apart anything that's smaller than about 3/4". Eventually, these hard steal hammers that have square edges get rounded off, and the spacers between them get kinda beat up; so about every 100-200 hours you have to drive out the shafts after removing some keeper pins and replace the spacers and at least rotate the hammers. You can usually rotate hammers 4 times until all 4 corners get rounded off. Then you replace them, too. This is not the most pleasant maintenance job in the world but isn't a show stopper to anyone mechanically inclined. I just did it on my old TroyBilt. I understand it's easier on the Mac because the hopper comes off, and you can get at the shafts from up top rather than wallowing around on the floor with the TroyBilt. Haven't done it on the Mac but have heard from another TBNer who has a couple or more times.
A guy is coming to look at my TroyBilt tomorrow to hopefully buy it. It's getting kinda long in the tooth in some minor ways but still works well after 15+ years. It's made of thicker steel everywhere than the Mac is, but it's a VERY noisey beast. Got it priced at $150, just to get at least my $75 worth of spacers I put into it. Sold the shredder-only Mac last fall to a guy with another Gravely to drive it. He wanted it to whack up his blueberry canes. Canes and leaves it did fine.
Ralph
/ Comments on Salsco 600 PTO chipper #29
Larry-
Sounds like we both want the same thing for the same money! I have read some good threads on the Jinma, and from what I have read so far it seems to be a good unit. They go for about $1700 plus shipping unless you can find one near you. I did find a dealer in Ct on the coast. If you would like to know more, send me a PM and I'll share it with you- I have not contacted them yet, but will probably give them a call soon to see what they have.
Good luck!
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2011 Kubota KX080-3 Midi Excavator (A59228)
2011 Kubota...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
