Come alongs/chains/
/ Come alongs/chains/ #1
Hillbilly
Platinum Member
Where/who makes a good heavy duty come along/winch.
I would like a heavy duty type,double ratchet,not one of these cheap aluminum light weight type.
What do you consider the best a cable type or chain type come along?
Also who is a good supplier of log/towing chains?
Any input or ideas would be appreciated.
Thanks
Hillbilly
/ Come alongs/chains/ #2
Sounds like you have a pretty good idea of what you want. I can't think of the name of the manufacturer right now, but we have several at work that would fit the bill. I have a cheapie I'd like to replace myself. One of the better hardware stores near me has a great selection. A couple years ago, I stumbled onto one of the chain-type comealongs at a used tool barn for $30. It only has about 6' of chain, but the thing I really like is that it is infinitely adjustable up or down. If you need 1/8", you got it. The cable jobs mandate a click at a time................chim
/ Come alongs/chains/ #3
Hillbilly, maybe it depends on what you call "heavy duty". Try <A target="_blank" HREF=http://www.maasdam.com/>this link</A> for what I have. They come in half ton to two ton models and I haven't been able to break mine.
/ Come alongs/chains/ #4
Be prepared to spend some bucks if you really want a heavy duty puller. I've used cable, strap and chain pulls and nothing compares to a chain! (but they are big bucks). If you ever see a used one grab it. I have acccess to 2, a 5 ton and a 2 ton, both make the cable and strap jobs look like a joke.
/ Come alongs/chains/ #5
I have a Chisholm Moore Model E chain puller(1.5 ton). Very nice machine. I wish it had a double acting ratchet. I have seen this model so tight that the chain would sing. These pullers use special chain so if you have the bucks and the strenth to lift it you can make it any length you want.
Chris
I rented a come along the other day...I think I will call the rental supply and ask them.I never thought to ask them where they got it when I returned it and I had to work this weekend and just thought I would ask the question while I was at work(doing nothing) and see what my brothers at TBN might have to say.This one I used was heavy one,but it done the job.
Bird....thanks for the link but those are not what I want.I appreciate it just the same.
What about some nylon straps....anyone?
/ Come alongs/chains/ #7
<font color=blue>"What about some nylon straps....anyone?"</font color=blue>
Try <A target="_blank" HREF=http://www.awdirect.com>AW Direct</A>. They are a supplier to the towing and recovery industry and have really high quality straps, straps with different ends, straps with chain ends, etc., along with high quality Amercian made weldable hooks, chains, etc. Check them out. I think you'll be impressed.
/ Come alongs/chains/ #8
Hillbilly, I was in a TSC store earlier today and they had the chain type; 1 ton was $69.99 and 4 ton was $99.99.
Thanks Gary and Bird......I have been hard on chains this winter,broke 2 or 3 and stretched one a while back,these chains I had for years....never thought I would mess a chain up........Anyway I am going to have to restock and get a good come along...to have on hand.
I am going to go up to TSC and look around.Gary I ordered a catalog from that link you gave me.I think I will get myself a heavy cable for the towing and try to use the chains for load binding.
Thanks
/ Come alongs/chains/ #10
Hillbilly
Northern deals in Ingersoll-Rand chain winches.
RonL
/ Come alongs/chains/ #11
While it is a bit distant, this <A target="_blank" HREF=http://www.bbchain.com/main.asp?SID=7bhzzQqVsFNxDkmmN8kCSBcxKkbmfcGDiLd>site</A> may give you some good ideas. I have found BB Chains prices to be reasonable - bought ratchet type webbing binders and such and have never had a problem.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2009 FORD E-150 CARGO VAN (A66091)
2009 FORD E-150...
CAT 416B Front Loader Bucket (A68134)
CAT 416B Front...
