Combines: Mid 80's Deere vs IH
/ Combines: Mid 80's Deere vs IH #1
derekuk101
Bronze Member
KY
M5-111, M8540, M4900, Ford 3600
If you had to choose which one and why? Looking at either a Deere 6620 or a Case 16XX? We don't have a lot of acres but looking for an improvement from the old Massey. What are some things we should look for when checking these old beasts out? Really looking for the one that is the easiest to work on and the best parts availability.
Thanks!
/ Combines: Mid 80's Deere vs IH #2
1640 or 1660 would be the best.when you turn the rotor on it should run smooth. if it has a lot of vibration it needs work.
/ Combines: Mid 80's Deere vs IH #3
I'd go with the IH rotary too . A 6620 is still side cab and a step sideways from the MF maintenance wise.
After many IH's points that come to mind .
Straw chopper bearings
Shaker/ seive bushings and side rails
unload auger gearbox
check rear axle for cracks around the pivot point
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2017 Ford F-150 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2018 John Deere 470G Hydraulic Excavator (A61567)
2018 John Deere...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
