Combination SSQA pallet fork & QH 3 point mount
   / Combination SSQA pallet fork & QH 3 point mount #1
SSdoxie
Elite Member
Cumberland Plateau, TN
Bobcat CT225
I don't recall who mentioned this on TBN a few months ago about making a 3 point mount on set of QA pallet forks to use on either end of the tractor, but it got me thinking. When I buy rolled hay I have to unload the trailer at the road and haul it back to the barn (about 1/4 mile) with the tractor, so wanted to haul 2 bales per trip. With bale spear on front to off load trailer and stack 2 high in the barn, I decided to see if I could rig up a 3 point, QH compatible, on the pallet forks. Here is what I came up with this weekend.
Started with 2"X2"X1/8" angle iron I had laying around. Notched the top end to fit in under top lip of QA frame and bottom. The small bevel at top is what I had to take off to clear any protrusion that interfered with the QA fit.
This is thin iron so I made 4 pieces to carry on each side of lift arm.
I didn't take progressive photos of the top link connection, but used 1.5"X1.5" angle with some 3" stock welded on for the top link pin. used 1.25" pins @ all 3 locations and tack welded them in since this QH and don't need to remove pins. Here is finished product.
It still fits the loader: 2013-07-28 18.47.12.jpg
And fits on 3 point: 2013-07-28 18.52.02.jpg 2013-07-28 18.52.31.jpg 2013-07-28 18.55.14.jpg
Only negative I have seen so far is the lower hooks of QH protrude in way of the fork id trying to relocate/slide past. Have to set the forks either outside the hooks or inside before hooking it to 3 point. 2013-07-28 13.30.14.jpg
If that is only problem, I can easily live with it. Just have to remember to move the forks out, when needed, while pallet frame is hooked on the loader.
   / Combination SSQA pallet fork & QH 3 point mount #3
Now all you need is a second pair of forks so you have a set for the front so you can do both front and rear at the same time. :thumbsup:
I did this so I could carry 2 bales of hay at same time, have a bale spear for the front. If I use it to carry firewood, I can but pallet fork on front and carry-all on back.
   / Combination SSQA pallet fork & QH 3 point mount #5
I think you will find the forks on the rear very handy.
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Komatsu PC220LC Excavator (A59814)
Komatsu PC220LC...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
