cold weather starting
/ cold weather starting #1
bmartin
nc
Farm Pro 2425
I have a Farm Pro 2425 [385 engine] with 21 hours on it. As the weather is getting cooler it is getting harder and harder to start. I have used the glow plugs for up to 60 seconds and they seem to be working at least they are drawing about 28 amps, still hard to start. My question is, is it ok to use a shot of starter fluid? Let me say this, this is my first diesel experience so I can use all the help I can get.
Billy
/ cold weather starting #2
Starter fluid and diesels are one of those delicate subjects.. kind of like torqueing a bolt.... " tighten it to just before it breaks!"
Even on the low compression gas engines I'm used to like old antique gas tractors.. we call that stuff 'head bolt loosener'.
No reason why a new diesel engine should have to rely on ether to start.
I might hazard wd-40 or something like that though...
Soundguy
/ cold weather starting #3
Anyone ever tried propane? Again.. I've heard stories.. but never 'seen' a propane assit start on a diesel engine.. though i have seen an old 353 with a bad fuel pump run off a can of wd-40 for diagnosis...
Soundguy
/ cold weather starting #4
Lots of opinions on using starting fluids. The forum search engine will help you see what's been said (and resaid) on the subject. Here's a Typical Discussion . Read a few, make up your own mind.
My feeling on the matter is that starting fluid is an emergency measure, to be used only by those who know HOW to inflict minimal damage with it. THEN, get to the root of the problem of WHY the engine is difficult to start.
//greg//
/ cold weather starting #5
Bmartin,
I see you are from NC that would be North Carolina correct?
Well I'm up in upstate NY and its a tad cooler than you folks get. Started my 224 yesterday, about 45 degrees and 15 seconds of glow plug time fires right up.
I have to agree with Greg and Soundguy that it can be used BUT with correct procedures and amounts. I've been mostly a diesel mechanic my whole career and have used it BUT really don't like to as the damage that it can cause. Like Greg added this does not correct the real problem. I've started mine down at zero without either. Plus I've never used my glow plugs more than 30 seconds at a start(this was a test to see if it would start on own at zero temps, I usually use my block heater for 20 degree and lower stuff). Just my opine but I think you may have other problems.
Give us more info about how long you have to crank etc. Have you ever tried using the "decompression" lever while starting?
Once I'm running it runs great its just starting that is a problem. I have noticed that the glow plugs pull 28-30 amps but I have never seen the drop to 25 or so that you should get. I haven't changed the fuel filter as of yet, could that be the problem? Since it runs great after it lights off I figured the filter was ok.
Billy
No, I haven't used the decompression lever at all. Mabe thats the trick?
Billy
Harry I am in North Carolina but my tractor is in the hills of SW Virginia and we have had a couple of mornings when it was below freezing and that is when it was realy giving me a fit starting. Iwill say this, I have a buddy with a Nortrac and he has replaced 2 head gaskets and I'll bet using starter fluid was the cause.
Billy
/ cold weather starting #9
Like I said, either in right measures and correct procedures does no harm BUT done incorrectly well I've heard of guys blowing up pistons, spinning bearings, head gaskets, not good things. With that said, some engines come with a either start system but its finely controlled.
Back to "decompression" lever. Do you have a Lever that sticks out of dash board? Some don't have the decompression lever but it holds the exhaust valves open with cranking and when you get engine cranking you release it to assist starting. Sounds like the engine has no compression. Which it doesn't because you are holding open valves. Really gets the engine RPMs up while cranking. Take a look and see if yours has one and get back.
/ cold weather starting #10
Take a look at THIS PHOTO Billy. Kinda hard to see, but #6 is pointing at the decompression lever location. The lever itself is the shiny vertical thing, just left of center.
//greg//
OK men, I do have a decompression lever but I guess I didn't know how to use it properly. I had tried it but nothing seemed to change so I gave up. I'll go back and give 'er a whorl and let you know what happens. But I promise noooo starter fluid!
Billy
/ cold weather starting #12
I was thinking intake,,,may be wrong,,did that valve adjust and head bolt retorque last winter,,,so I knew than,,now,,,well that was 10 months ago,would make a difference I think and exhaust sounds more logical but forget,,hold decomression open,,turn it over a couple times,than let decompression go back,[let go],,turn it on glow plugs for about 15 seconds while useing slight throttle,,let off glow plugs and hit start,while giving it maybe 1/4 throttle,,,when it starts,don't give it a lot of throttle till it warms up,,,if you watch the oil pressure gage,,you will see it start to decrease when motor is warm,,something like that,,,thingy
/ cold weather starting #13
</font><font color="blue" class="small">( I do have a decompression lever but I guess I didn't know how to use it properly)</font>
Spinning the starter motor with the compression released does two things:
(1) Understand that your compression ratio is about 22:1, and that it's not a very big starter in the first place. So releasing the cylinder compression BEFORE spinning up the starter saves wear and tear on both the starter and on the battery.
(2) Understand also, that this is a compression-ignition engine; in that a cylinder won't "fire" until its fuel/air mixture is "squeezed" past the point where it's hot enough to explode. That said, gravity causes engine oil to drain back to the oil pan in an cold/idle engine. Spinning the starter with the decompression lever open, permits oil to get splashed back toward the rings and upper cylinders BEFORE things start exploding up there.
Set hand throttle at about 50%. Turn the ignition key to HEAT and observe the ammeter deflection. Do a slow count to 30, watching for the ammeter needle to start moving to the right. That means the glow plugs are throwing good heat. When the ammeter drops under 20A - or upon reaching your slow count of 30 - grasp decompression lever with left hand and turn 90 degrees;, right or left, doesn't matter. Then
turn the ignition key all the way over to START. Let the starter spin for a slow 3 count. Then release the decompression lever, but keep cranking the starter for up to another slow 7 count. As soon as you release the decompression lever, you'll hear the starter motor RPMs drop. That's a sign that it's now working harder against that 22:1 compression.
If it doesn't start/run, wait 2 minutes for the starter motor to cool down to repeat the procedure. Pretty soon you'll find the "sweet spot" on the ammeter needle that tells you the glow plugs are warm enough, but it's not a wise idea to heat them for more than 30 seconds at a time.
This is a "<i>first start of the day</i>" procedure; glow plug heating is not necessary on an engine that is still warm. But I do recommend using the decompression lever each time you start it back up.
//greg//
Thanks Greg , I'll see if I can get it right next time.
Billy
/ cold weather starting #15
Martin:
all good replys so far: what kind of smoke are you getting out of exhaust when cranking? white or black or inbetween>?
I posted this before but if it is very cold warming the injector pump & lines on mine helps it alot! I use a shop light (halogen 500 watt one) and set it on the right front tire shinning at the injector pump/lines. the lines are black and they WARM pretty quickly this is the NEW fuel that first gets into the cylinders and will light off faster than most and the warmer pump also helps the newier fuel comming... others prefet the block heaters and while I admitt they are great I don't start mine more than one or two times in a month when it is really COLD so rnning the block heater seems to be a waste to me. I MAY eventually get one installed but have been using the light method down to -10 degrees when I got STUCK with the car comming into the farm last winter and it worked fine. I also have an OLD BLANKET I tossed over the hood when I was doing this that day as the wind was hollowing. I was soaking wet after slidding into the yard and having to tromp 400+ feet to the house and then farther to the barn with out any boots or carharts (first trip then I got them on!) /forums/images/graemlins/crazy.gif
anyhow I also use a slight bit of Kerosen in the fuel for winter use to lower the octain a bit, usually about 1/2 gal K1 per 5 gallon of fuel. I also just use ON-ROAD deisel as it is more available around here and doesn't require going INSIDE to prove I have a farm... Mine (Jinma284) barely smokes when running on the on-road even under HEAVY LOAD it only darkens up a bit... I use glow plugs for 20sec or less even when COLD and rarely use them when it is warm. Mine will usually pop off in about 3~6 sec of cranking and if it don;t after the first try I wait 20~30 sec and hit the glow plugs for 10~15 sec then crank no more than 15 sec. She will fire usually the first time when it is over 30 and the 2nd try if under 30. when it was really cold it took 4 tries but I also didn't let the light set on her only long enough to run back to house and get the car harts on... (I by-passed house and went straight to barn to put on the light hopeing and praying she would start as it was off over a month that time.) could have been low fuel in the lines why it didn't start or fack the battery was a bit low cold? I was thinking of trying the decompression lever but I still have yet to use that for anything other than MAINTENANCE when adjusting the clutch plates...
other causes could be a timming issue with the injector pump on you'res if it starts hard anytime even when warm... there is some really good info on that lower down.
MarkM
/ cold weather starting #16
A farmer down the road from me uses Heating Oil in his JD. He claims it is cheaper than off-road and has some anti-jell properties. That said he has a lot of problems with his tractor. I told him he is probably getting crap/rust from the bottom of his underground tank.
Does Kerosene raise or lower the cetane rating? How is the cetane and octane rating related?
2017 Peterbilt 320 New Way 20ASL 20yd Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
2013 C&M TRAILER T/A GOOSENECK TRAILER (A67714)
2013 C&M TRAILER...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
John Deere 4045 4 Cylinder Power Unit w/PTO (A64911)
John Deere 4045 4...
2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
2023 Maybridge M79...
