Cold Weather Starting
   / Cold Weather Starting #82
After cleaning the tank, and remove the ???tin foil??? from the elbow on the bottom, and am happy to say that the PT is running very well.......for now.
Hopefully it will be awhile before it serves me another "project".
Thanks for the tips and suggestions guys, as always PT'rs (and others) on the forum are extremely knowledgeable and very helpful.
Thanks again.
   / Cold Weather Starting #83
Thanks again.
That's great news!!
   / Cold Weather Starting #84
Thanks. Now if I can just find some time for some "seat time" :D
   / Cold Weather Starting #85
Just a note:
I have an Ariens Zero Turn hydraulic mower with a 17hp B&S. I parked it last fall in the shed.
Today, I went out, put it on choke, turned the key, and 2 seconds of cranking it fired right up, with a slight puff of grey smoke!
This engine is nine years old! I have never had a problem with it.
Now, I know with the PT there is some drag from the hydraulics, but I also keep it in a insulated garage, with a drip charge, and I baby it, and sometimes, no....most of the time I talk real sweet to the Robins Engine.
But it never starts like the B&S in the Ariens!
Could care less if I ever even hear the name "Robins" again (once this one is gone).
Just consider this a "rant" :)
   / Cold Weather Starting #86
Sorry to hear about your starting problems. I have a 422 with Robins engine and keep it in an unheated garage with no charger connected to it. It usually starts right up down to about 30 degrees any lower than that it might not start on the first try. I have almost 1,400 hours on it and it is 10 years old, the only thing I have done to it is routine maintenance and change the spark plugs. The battery is still the original that was in it when I got it.
   / Cold Weather Starting #87
To me Ernemats,
that should be the norm.
Glad it is for you. But I don't think that it is for most.
   / Cold Weather Starting #88
something to check on your machines the negative cable on my machine was not tight enough to adequately charge battery and also slow crank condition, I removed the cable, the paint had not been removed for a good ground and the bolt was corroded, to remedy I installed a stud in place of the original bolt, ie:next size bigger bolt gently massaged with my short handled 8lb ball peen hammer:cool: then installed a star washer between body and cable end with a liberal coating of heavy grease then a nylock nut to keep everything tight, this was always standard fix it procedure for the diesel trucks that would not start/slow crank in the winter time, hope this helps
   / Cold Weather Starting #89
Thanks, something to look at.
   / Cold Weather Starting #90
I have always had the same problem, But only when the temp goes under 10 degrees, This year I'm gonna try two dipstick heaters from Tractor Supply (cost under $20.00) One in the engine and the other in the hyd. tank.:confused:
   / Cold Weather Starting #91
I would recommend something a little beefier for the hydraulic tank, like a magnetic heater. Plus, you won't have the main vent open for crude to fall in while you are heating it.
I have to admit that since Bob's posting on the high vacuum in the summer time, I have been running the PT a lot slower until the oil tank is warm. Thanks for the heads up!
All the best,
Peter
   / Cold Weather Starting #92
Okay, that is one thing that i question. The PT is always pumping oil right from start up. The only question is do you just let it return to the tank or do you use it. Is it because it is pumping against low pressure when it sends the fluid to the return that it is better to do that than say drive slowly?
Because the fluid heats up relatively quickly from just idling, it is clearly doing some work as it goes through valves, bypasses etc.
Ken
   / Cold Weather Starting #93
If you are talking about the hydraulics, the charge pump is always pumping about 10 % or total flow. Driving slow is OK, and will eventually heat the hyd fluid . Working all three pumps will improve the heat up time. You can be driving slowly, and making the FEL valve bypass, and if you had a hyd motor in the PTO circuit, all three pumps would be contributing to heating the hyd fluid.
   / Cold Weather Starting #94
Dear Ken,
Here's my logic. If under cold flow the filter experiences significant back pressure, i.e. vacuum (per Bob999's post), then low engine rpms should minimize that the risk that the filter collapses, or that the vacuum gets high enough to cavitate. So why not run the engine at lower rpm until the oil is warm?
Since the charge pump is making up for leakage in the pumping circuit, it, as JJ notes, isn't pumping much volume, but it still can, and does, develop significant vacuum.
My thinking was that by not running at higher rpm, that the leakage from the drive motors is minimized, thereby minimizing the charge pump flow. Meanwhile, as you note, the PTO pump is running continuously and warming the oil, along with all of the return from the auxiliary pump plus any return from the motors. As you note, all of that moving oil generates heat. I'm just waiting for the oil to warm up before really revving the engine.
How's the logic?
Would a magnetic tank heater and warm oil be better? Without a doubt! But I don't always plan that far ahead. Perhaps one of those eksbar diesel heaters on the PTO overflow to warm the tank quickly... :)
All the best,
Peter
Ken
   / Cold Weather Starting #95
I tried a dipstick heater. It was a total waste of money and effort. Not enough wattage and not enough surface area = no noticeable effect.
I am using one magnetic block heater on the hydraulic tank and another on the top of the tram pump. The combination has made a useful difference. I would still like to find a way to heat the engine.
   / Cold Weather Starting #96
Dear Ken,
How's the logic?
I agree with most of your logic with the exception of the underlined phrase. My understanding is that the charge pump flow is determined by engine RPM and that the charge pump flow goes to make up wheel motor leakage and the remainder flows through the hydraulic cooler circuit before returning to the tank.
   / Cold Weather Starting #97
Do you ever look at an old post of yours and think, I could have phrased that better?
I agree with your clarification. Thanks!
I'll double check my plumbing; I had never thought to look where the excess flow from the charge pump went.
All the best,
Peter
   / Cold Weather Starting #98
You really can't call it excess, in the fact that pump is a gear pump and is pumping when the engine is running, and at about 10% volume of the max tram pump volume. So, what ever is needed to makeup lost fluid because of wheel motor leakage, and if no lakage, the fluid is passed on through the tram pump case for additional cooling, and then to radiator. That is why, when you think of filtering, the GPM's that are filtered is the charge pump volume. If you have a 3 GPM charge pump, the suction filter can filter about 180 GPH at max engine rpm. At idle, the charge pump is working very little. So at idle, all 4 pumps are working pushing fluid. You could ad extra heat by makng a valve go to relief, and/or driving the PT.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
KOBELCO SK170-9...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
CATERPILLAR OFF ROAD WATER TRUCK (A60429)
CATERPILLAR OFF...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
2013 FORD F250 (A60460)
2013 FORD F250...
