Cold start problems
/ Cold start problems #1
nerodino
uk
kubota
Hi, I have a Ransomes mower with a D1105-B Kubota 3 cylinder engine, when the mower is cold it is an absolute pig to start.(when warm its on the button!) the timer for the glow plugs has been disconnected and you just hold the button manually to preheat. what i want to know is what is the injector pump ETR solenoid mentioned on the wiring diagram? as i notice that this is powered when the ignition is on but the relay open circuits when you turn the starte over and hence power then is removed from the ETR. Is this correct? also i notice that their is no smoke when turning starter over from cold and its as if the injection pump lses its prime.....eventually smoke appears and it will start (if the batery isnt flat first!) Any experts on this please?
Regards
Graham
2014 Chevy Malibu Sedan (A59231)
2014 Chevy Malibu...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A59228)
2006 GEA Westfalia...
2014 Freightliner Cascadia 125 S/A Day Cab Truck Tractor (A59230)
2014 Freightliner...
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
