CoyPatton
Veteran Member
- Joined
- Aug 10, 2015
- Messages
- 1,640
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
A pressure leak down test checks the integrity of the cylinder. You want to rotate the engine until both valves are in a closed position. Then you charge the cylinder with air pressure with a gauge in the line. You remove the air supply with the line closed so that pressure is maintained to the cylinder. If it loses pressure, you check for where air is escaping. You will possibly have to reattach air supply.
This way you can determine what is at fault in the cylinder—valves, rings, head gaskets by where you find your air loss escape path.
If the valves are out of adjustment, you will not find that with a radiator leak test ever. Nor will you know if the rings are bad.
Bottom line, I would hate to do put a head gasket on only if the engine needs to be rebuilt!
