Cold running problems
/ Cold running problems #1
Broncofarm
I have a 2024 MT3 57 with about 100 hours. After the weather turned cold I am having some issues. If the tractor is left outside, temps around 5 degrees. It starts fine but after 3-5 minutes it dies out. It will restart for a few seconds then dies again.
After having the issue I left it inside in a warm shop and the next day it started fine and operated for 10-15 minutes without issue.
Then I left it outside again for 2-3 hours m, it started fine and after a couple minutes died out and had the same issue.
Unsure if it will die out after longer use when coming from a warm shop. I need to test that after the problem resurfaced again last night.
Any ideas what is causing the issue? I thought once started in the cold it would be fine and not die out a few minutes later.
Thanks for any ideas.
/ Cold running problems #2
If it is 5 degrees I suspect your fuel is gelling. Have you added any fuel treatment to prevent gelling?
Check your fuel filter to see if it is cloudy.
I use Power Service (white bottle) or something similar available at most auto parts and tractor supply stores. It says prevents gelling on the bottle.
You can also add #1 kerosene to your #2 diesel. Maybe a 50/50 mix.
/ Cold running problems #3
I add treatment to every gallon I use, because I then don't have to pay attention to when it gets cold, or what fuel was left in the tank
/ Cold running problems #4
To me it sounds like maybe you should try installing a new fuel filter
/ Cold running problems #5
You probably have summer mix diesel - do the anti jel additive and go get some fresh diesel and be sure and ask if its winter diesel. If they cant answer - buy elsewhere. You can also have water build up in the fuel filter that is freezing preventing proper fuel flow. Empty the water out of your fuel filter.
I have an mt352 the same exact engine had the same thing happen the first winter I had it. Dont buy cheap diesel at a local gas station - go to a truck stop that has high turnover on the fuel where over the road guys buy their diesel.
/ Cold running problems #6
Been nearly a week Have you made any progress getting the issue fixed ?
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
John Deere 7R 210 (A64126)
John Deere 7R 210...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
John Deere 1025R (A62177)
John Deere 1025R...
