Code Needed For Blinking Light
/ Code Needed For Blinking Light
Letting the engine idle to long can soot up the EGR valve and cause it to stick. Next time you have the engine idling a while through it wide open and note if the engine stumbles and huffs a lot of black smoke till it reaches high RPM. That's a sign the EGR is loading up.:thumbsup:
THANKS BUD, PRECIATE THE RESPONSE!
/ Code Needed For Blinking Light #12
Check all the little grey vacuum lines.. be sure none have popped of their port or are cracked or chewed up by rats... this is very common with 6530s...
/ Code Needed For Blinking Light #13
If not there you may look into advancing the fuel pump... usually works wonders on 30series tractors
Thanks Navasot, I'll check that as well.....SOON AS I CAN GET OFF THIS DANG OVERTIME!!! lol
/ Code Needed For Blinking Light #15
5 Blinks is a EGR valve malfunction. Are you letting the engine idle for long periods?:confused3:
I have an emax 22 with flashing light 1 long 1 short. Any ideas
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2014 Jeep Cherokee Sport SUV (A59231)
2014 Jeep Cherokee...
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
