Cluthc/Transmission question
/ Cluthc/Transmission question #1
PoconoMan
Uniondale, PA
Yanmar 276D
I've been an automobile mechanic for the last 20 years and recently bought my first compact tractor. It's a Yanmar 276D and honestly, I don't know too much about them. My question is, when using the tractor, in any gear, I release the clutch pedal from a dead stop and the tractor just sits there for about 3 to 5 seconds then it engages as if it were an automatic transmission that was idling too low. But this tractor has what I assume to be a conventional dry clutch which in an auto application, should engage as the pedal is released. I was moving snow and when I tested the clutch against a snow pile, it will stall the engine so I would think its not slipping. It has a "power shift" transmission, whatever that is as well.
Sorry to be long winded!
Thanks!
Sean
/ Cluthc/Transmission question #2
You need to clean your pickup screen and replace the hydraulic fluid with a JD303 type fluid. The symptoms are not uncommon for your tractor.
Bruce
Thanks Bruce, I really appreciate your help. I was a little worried as I bought it "unseen undriven" and thought I had made a mistake.
On another note, I see that you have a website for Yanmar's. I'm going to repaint this tractor and was wondering if you have, can get, or know where I can get a complete decal package for it.
Again, thanks.
Sean
/ Cluthc/Transmission question #4
hello Sean, welcome to tbn. yes, you can get decals for yanmar. while there maybe other sources, you may want to start looking at hoyetractor for these types of things... they're at www.hoyetractor.com.
good luck -arthr
Thanks for the welcome as well as the link for the decals arthr, I appreciate your help.
Bruce; I did as you recommended today and you were right, tractor now engages tight as a drum. Many thanks. There was allot of what appreared to be blue paint chips and flakes in the screen. I can't imagine that they paint the inside of the cases,..do they?
Thanks again,
Sean
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
5ft. Wooden Cowboy Statue (A61574)
5ft. Wooden Cowboy...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
