Clutch wear
/ Clutch wear #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
Hi, this is the clutch adjustment of my Kioti LK30. I have about an 1.5" of play in the clutch pedal while the service manual calls for 0.8"-1.2" of play. The adjustment seems to be to its further end (ie, cannot reduce the play anymore). Does this mean the clutch is almost worn out? It's a dual stage clutch (PTO and transmission) if it matters. The clutch doesn't slip so far. Thanks.
/ Clutch wear #2
Clutch disc wear typically increases the pressure plate finger height which in turn decreases pedal freeplay when the external linkage pulls the rod to disengage the clutch.
/ Clutch wear
So you're saying that has the clutch wears, the free play decrease and I'll need to move the rode out so essentially, the wear is minimal here?
/ Clutch wear #4
Things that increase free play may be a stretched cable, worn pivot points, worn throwout bearing, bent or worn clutch arm, worn pressure plate fingers.
/ Clutch wear
So, for a tractor having 510 hours (I know it also depends on how the clutch was ridden) and from what I said and the picture above, should I be concerned with its clutch wear?
/ Clutch wear
Great, thank you. Although I somewhat know my way around car's mechanic, owning a diesel tractor is new to me so I prefer being safe than sorry :)
TANK MANIFOLD (A55745)
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
John Deere 5055E (A53317)
John Deere 5055E...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
