Clutch wear
/ Clutch wear #1
SylvainG
South West, Qc
Kioti LK30
Hi, this is the clutch adjustment of my Kioti LK30. I have about an 1.5" of play in the clutch pedal while the service manual calls for 0.8"-1.2" of play. The adjustment seems to be to its further end (ie, cannot reduce the play anymore). Does this mean the clutch is almost worn out? It's a dual stage clutch (PTO and transmission) if it matters. The clutch doesn't slip so far. Thanks.
/ Clutch wear #2
Clutch disc wear typically increases the pressure plate finger height which in turn decreases pedal freeplay when the external linkage pulls the rod to disengage the clutch.
/ Clutch wear
So you're saying that has the clutch wears, the free play decrease and I'll need to move the rode out so essentially, the wear is minimal here?
/ Clutch wear #4
Things that increase free play may be a stretched cable, worn pivot points, worn throwout bearing, bent or worn clutch arm, worn pressure plate fingers.
/ Clutch wear
So, for a tractor having 510 hours (I know it also depends on how the clutch was ridden) and from what I said and the picture above, should I be concerned with its clutch wear?
/ Clutch wear
Great, thank you. Although I somewhat know my way around car's mechanic, owning a diesel tractor is new to me so I prefer being safe than sorry :)
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
1996 International 4700 (A64127)
1996 International...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
