Clutch slipping sometimes
/ Clutch slipping sometimes #1
Nzguy
Christchurch
Landini
Hi, my landini mythos clutch slips sometimes once the tractor is hot and working hard! I can't make it slip if I try any other time and pushing the clutch pedal in will set it going again for another few minutes! It's a wet clutch shuttle shift so may this be solenoid related? Thanks
/ Clutch slipping sometimes #2
I don't see wet or shuttle being part of a problem like I would consider "due to wear, the linkage needs a tweak". Since it's wet, the slippage could be the oil is thinner when hot and add that to the linkage needing a tweak may be your "why". Never worked on such, just brainstorming, but you asked. Maybe this helps!
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
Quick Attach Concrete Mixer (A65579)
Quick Attach...
2007 Freightliner Columbia 120 Single Axle Day Cab (A62613)
2007 Freightliner...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
