Clutch slipping sometimes
/ Clutch slipping sometimes #1
Nzguy
Christchurch
Landini
Hi, my landini mythos clutch slips sometimes once the tractor is hot and working hard! I can't make it slip if I try any other time and pushing the clutch pedal in will set it going again for another few minutes! It's a wet clutch shuttle shift so may this be solenoid related? Thanks
/ Clutch slipping sometimes #2
I don't see wet or shuttle being part of a problem like I would consider "due to wear, the linkage needs a tweak". Since it's wet, the slippage could be the oil is thinner when hot and add that to the linkage needing a tweak may be your "why". Never worked on such, just brainstorming, but you asked. Maybe this helps!
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2005 International 4300 Rollback (A62613)
2005 International...
SDlanch SDLL580 (A64127)
SDlanch SDLL580...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
John Deere Planter (A62613)
John Deere Planter...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
