Clutch Problem
/ Clutch Problem #1
DanSullivan
Fayetteville, TN
JD 2755
I have an '88 JD 2755 with synchro trans and manual clutch. Shaft does not stop completely when clutch is depressed. I must go to low idle and select gear 4/8 before selecting range, or it will grind before engaging range. Gear 4/8 is the only gear that will engage without grinding. Clutch pedal free travel is adjusted to 1 inch. Anything else I can do before separating housing?
/ Clutch Problem #2
If you have plenty of engagement distance where the clutch grabs and then your pedal free travels on up toward you AND it's an adjustable clutch,I'd adjust it to engage more near the top of its travel.
If it's a hydraulic clutch,bleed it thoroughly. don-ohio :)^)
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
