clutch grinding??
/ clutch grinding??
And the winner is... inertia brake adjustment! I adjusted the inertia brake last night just a little, and the grinding noise stopped. Tonight I adjusted the clutch so it had more play, and the grinding noise came back. *arg* Then I adjusted the inertia brake again (adjusting the clutch threw off the inertia brake adjustment) and the grinding went away again. :thumbsup:
Thanks everybody for your help! Especially Winston who guessed right on the inertia brake. It's time to celebrate. :drink:
/ clutch grinding?? #22
My guess is the Inertia brake linkage must be lightly applying the brake and slowing the rear end gears,etc. to allow a smooth power shift. Huh!! sounds like One Fancy setup there. :thumbsup:
/ clutch grinding?? #23
o.k. I'll bite, if my powershift sifts firm, can I adjust to soften the response ?
/ clutch grinding?? #24
Glad it was simple fix I had figured as much! :thumbsup:
I use a different terminology is all but talking about the same thing. As it was explained to me by a Yanmar person there is a release valve associated with the inertia brake that dumps pressure to the clutch packs to help shifting also.
I cant prove it either way my manual is pretty vague on exactly what does what. But it does appear there are 2 ports in the clutch shaft next to the brake assy one is dark and one isn't which usually means fluid or not. fwtw
/ clutch grinding?? #25
From what I have been told or have personal experience with-no adjustment. A firm shift is a normal thing on these a soft shift would probably mean trouble jmo.
/ clutch grinding?? #26
GOOD question? I sure would like to see a parts Dia. and see how the Inertia barke setup works. May want to upgrade mine to a Power Shift. I just so happen to know were a parts tractor is close by. Hah!!!:p Steve.
/ clutch grinding?? #27
CarDoc, Carey
I am with you..
Its my understanding that firm is good, just wondered what other minds were thinking.
I love the powershift, thought it would be real nice if a simple adjustment made it a smoother transition.........
336d in CT
/ clutch grinding??
I remember seeing on a thread here with some pics by a guy in Poland who tore apart his Yanmar transmission. You could search and find them. I believe it was last year some time.
/ clutch grinding?? #29
Here is what I have on the inertia brake on 336 and probably 3110,3220,3810 and so on all similar is my guess including the 2210 G has. Its black and white or I could tell you exactly what they do the ports that is.
  • YM336 powershift inertia clutch digram0001.pdf
/ clutch grinding?? #30
IMHO - These are similar to an automotive AT but lack the torque converter which cushions some of an AT's shifting shock.
The clutch packs inside the Powershift are similar to a multi-disc motorcycle clutch, where noticeable slip after a shift means excessive wear.
/ clutch grinding?? #31
Bingo well put. :thumbsup:
/ clutch grinding?? #32
Why I was guessing "Brakes" not Hyd. I can't find anything on it Could it be the Actual Notorious "Wet Brakes" It is a Fred. Tractor LMFAO:laughing:
/ clutch grinding?? #33
When I was drag racing I used a powerglide and it had a line "brake" or as it was called a trans brake.
All it consisted of was a solenoid that applied the low reverse clutch and the direct clutch (if I remember right those 2) which essentially locks the geartrain up solid thru some carefully placed ports in the valve body.
And when you released the button it dumped pressure on the direct clutch releasing it and away you went.
/ clutch grinding?? #34
I ran a power glide in a 69 cutlass 455. That was my street rod back in the day. actually loved the 2 speed:cool:
/ clutch grinding?? #35
That was MJ Peterson. He is an american missionary or preacher that lives in Poland. Look him up on here he did take it apart and do something to the ball bearings in it or something. Cleaning wise?
/ clutch grinding??
Actually, it was a different guy in Poland. I remember seeing MJ chatting with him in Polish, at least I assume it was Polish! :D
/ clutch grinding?? #37
OOPs, i thought MJ did pull his valve body apart and do something with the ball bearings.
/ clutch grinding??
Well, maybe he did too, but there was another guy who posted pics of the inside of his transmission... I wonder if I can search it up... nope, can't find it.
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
2018 Ford Focus (A61574)
2018 Ford Focus...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
