CLR to flush radiator system
/ CLR to flush radiator system #1
tony45
west milton,ohio
iseki ts2205
Any body ever used it if so and how did it work. need any advice you might have , Thanks Tony
/ CLR to flush radiator system #2
Yes I've used CLR.
But vinegar works better.
/ CLR to flush radiator system #3
A coworker used it and decided to leave it in for a week to eat away at the scale. The end result was it attacked some of the copper and brass parts forcing him to replace several sensors and the radiator. If it was me I would stick to a commercial product. vinegar does work but the people I know who use it say you should then flush the system with baking soda then flush it again with water. At some point it seams like just buying something designed to do the job makes more sense.
/ CLR to flush radiator system #4
Those "products designed to do the job" require flushing as well. Neutralizing active ingredients is never a bad thing.
An entire system "flush" for a prolonged period is something only an idiot would do. Or a calculated and informed person. I'm not saying there are such people qualified as in the latter case. Your "coworker" seems to have failed the grade.
Thanks for the input I will not try it, Tony
/ CLR to flush radiator system #6
I agree,if the "coworker" had used CLR with a little common sense,it would probably done the job.
/ CLR to flush radiator system #7
I personally have never had any luck with CLR. It never works the magic you see on TV.
/ CLR to flush radiator system #8
I normally use dishwasher soap. I prefer the granules, but I'm sure liquid would do the job.
/ CLR to flush radiator system #9
If it is the radiator that is badly plugged, pull it and take it to the pros at a radiator shop. I had an older bronco I bought used that had an overheating problem with lots of junk in the system. Pros pulled it and boiled it out, and also did and engine block flush in their shop - fancy machine they connected up to the hoses and flushed while it ran. Money well spent as afterwords I had zero issues.
/ CLR to flush radiator system #10
Ford Motorcraft makes an excellent product to clean cooling systems. Yes, it requires a flush afterwards.
Motorcraft VC9
/ CLR to flush radiator system #11
They sell some prestone stuff at Wal marts for that too. I drove around for a day with it my truck a while back then re-flushed it. A week is a long time.
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Iranch High-End Tricycle (A64119)
Iranch High-End...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
