clearing understory - can I avoid the turtles?
/ clearing understory - can I avoid the turtles? #1
ohbehave
Bronze Member
Knoxville, tn
Kubota L3200 (2012)
I love that there are box turtles in my woods.
My woods are absolutely full of honeysuckle and invasive privits as an understory. On the floor is pretty much blanket of English Ivy. I'm ok with the Ivy.
Also, there are these 5" high box turtles...I'd like to avoid them.
I'll be buying a 30hp tractor with a front loader to knock the understory down and push them into a pile. I'll also be using a bush hog.
I've never operated a tractor before, but can a bush hog be used at a level high enough (and yet, level) to avoid turtles?
It's not like I can guarantee no turtle harm, but if it is too low, it could be bad.
I just don't know about bushhogs at all and how they are adjusted.
/ clearing understory - can I avoid the turtles? #2
There are two height adjustments.
The 3pt hitch and top link combination set the basic height while the tail wheel is also adjustable and attempts to keep the blade from digging into the ground when following uneven ground....
I'd be worried about several things...different bushhogs have different amounts of tail wheel adjustment...go for one that will give you a lot of vertical lift.
typically, driving a tractor around in confined spaces results in the wheels covering a lot of ground = squished turtles unless you spot them first.
/ clearing understory - can I avoid the turtles? #3
The turtles are there because of the habitat, remove the habitat and they will be gone anyway. More to your question I think it would be hard to avoid them just driving through the area.
MarkV
/ clearing understory - can I avoid the turtles? #4
I built some trails through similar type terrain - woods with understory of a lot of honeysuckle and autumn olive. I only used my FEL and box blade. Unfortunately I wasn't able to avoid a turtle. Ran over him with probably a back tire. The worst part was he didn't die. About 1/3rd of his shell was crushed in and I think there might have been some organs exposed. I didn't have anything to put him out of his misery. Ever try to chop a turtles head off? It disappears as soon as you grab them. The next day he still wasn't dead. I took him to the NC State vet school where they have a turtle unit - who knew? I doubt they saved him but at least they could put him down easy.
I shared this story with a friend who bush hogs about 5 acres of pasture several times a year and he said he'd had the same experience. I think it's unavoidable if you're tractoring in turtle habitat.
Oh, I'm aware of that Karma problem.
My intentions are to create turtle friendly areas (and maybe improving it).
I do not think the honeysuckle plays a role in their habitat. The honey suckle is basically 15' trees.
What these turtles like is the damp, very shady environment.... the shade will remain. Also, honeysuckle and privet are not native anyway.... but the turtles are.
I'm thinking of teaching my girlfriend to use the tractor. Then, I'll walk ahead of the tractor as it slowly creeps through.
Accidents are unavoidable.
Interestingly, I created trails through the woods last year (by hand and using my riding mower as a kind of bushhog). In the spring, I saw plenty of turtles on the trail. Its almost like they appreciate an open area to walk without having to crawl over everything. I bet the English Ivy is a real hassle for a turtle.
/ clearing understory - can I avoid the turtles? #7
I would just do it by hand, thats the only way to avoid them for sure. Unfortunately turtles and big machines don't mix well. I'd love to have some turtles in my woods, but they all stay by my pond except for egg laying season when an army of them digs up the yard.
/ clearing understory - can I avoid the turtles? #8
You don't list the size of the lot you are clearing, but you can do away with vines and small brush pretty easily with a weedeater. For tough stuff get one with a saw blade on it and just walk thru it. It has to be a straight shaft type to use a saw blade. Stihl makes a really good one with two handle controls, just slightly less expensive than a tractor but might last just as long. I used one (not a Stihl) to clear the fence line and road ditch at my place last summer. The saw blades are awesome. You would be moving slow enough that you could see your turtles and they could crawl away also and you can pick your height to cut. You can cut 2" diameter trees with them easily, but you still might have to come in with the tractor to pile it all unless you can just let it lay and rot.
In the tractor use, lets say you have a 30 HP with 12" wide tires x2= about 2 feet and the tractor is going to be about 5 feet wide. So you are going to be laying rubber down 2 feet out of the 5 so those poor turtles have about a 60% (3 out of 5) chance of not getting squished. I sure as heck wouldn't play that game of Russian roulette with them if I valued their lives.
NOW as for myself, when driving on the road or bush hogging, if I see one I will avoid him but don't shed a tear if I do happen to squish one either.
AS for you, If I were in your shoes, I would use the FEL on a tractor to push thru those vines and pile them up. If you happen to pick up a turtle, he is less likely to be hurt by scooping him into the FEL bucket. When you have a loaded bucket, lift it high and dump it slowing to sift the turtle out and let him crawl away. Put one of those Piranha tooth bars on the FEL bucket and it will shear those vines and small saplings off.
Thanks. I'll check into the piranha bars.
My plans also included a small series of ponds designed just for the local critters (with plenty of cover). I don't have any ponds right now.
Many times, I can just push honey suckle over just by hand.... the roots are wide, but shallow as heck. Some are too stiff.
But on 6 wood acres full of honey suckle....that's a lot of work.
The tractor is primarily to clear the big stuff. Remove the huge and almost dead black walnut trees...there are tons of felled trees.....and then use a post hole digger to re-forest the areas that I have cut with more desired trees... like pecan trees, hollies and native, robust trees.
I hope to use many of the old, downed trees for firewood and use some of it to create a funky area with the dead would further back for habitat/hiding areas.
Then, I want to figure out how to plow and plant a crop using a tractor. I have no idea on that stuff nor do I know anything about the essential implements for it.
/ clearing understory - can I avoid the turtles? #10
I would think a bush hog would raise them up with the blades acting like a suction or the movement or noise of the blades or blade making them try to get out of the way and get hit anyway.
Rob
Ok... I'll have to be careful. That's about all I can say.
It is nice to know that there are members that can sympathize with my turtle worries!
/ clearing understory - can I avoid the turtles? #13
to bad they arent snappers you could make soup
/ clearing understory - can I avoid the turtles? #15
Technically, they do age, they just don't show signs of age. Everything ages, time marches on.
/ clearing understory - can I avoid the turtles? #16
Why not get a backpack sprayer and use roundup on the plants/areas you want to change. That way no turtles are run over or cut up.
/ clearing understory - can I avoid the turtles? #17
I can rent my dog out to you. We rescued him last spring at 6 months of age. I put him in a kennel of a day and let him out when I get home.
I have an area behind my house with a small spring and undergrowth like you. We stopped counting at 11 box turtles; he would catch and bring them to me. I would mark them and take them to a different part of the property and release.
I can rent him by the day or turtle:thumbsup:
He also brings moles, lizards, rabbits, and squirrel to me. He is like the cat we never had.:D
I told my wife it is most likey because he was set out at an early age and had to hunt for survival. He also is constantly chasing grasshoppers and butterflies.
/ clearing understory - can I avoid the turtles? #18
I would not worry about a rotary cutter for this issue as it is not needed.
The only way is to pull them out or dig them out.
If you purchase a large,medium and small brush grubbers from Gemplers and a
bit of 1/2 inch chain, chain hooks, and a pair of shackles sized for the chain and
the tractors rear hitch you will be ripping out the honeysuckle quickly and
effectively as well as any other heavy brush quickly with very lttle effort other
than attaching the brush grubbers to the offending plantlife.
I would ask that the tires be loaded with either rim guard or windshield
washer fluid and also purchase set of logging chains for the rear tires as the
R-1-and R-4 will lose traction if the tires are not loaded.
AND LOGGING TIRE CHAINS ARE YOUR FRIENDS IF you have mud that sneaks
up on you before you can back up anyway.
AND No no tow truck is going to come and pull you out of the mud unless its
next to a road(been there done that$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
this is other good reason for owning and mounting a 12 volt winch on your
new mule that will yank 10,000 pounds.
The other thing is you can also use the bucket to simply bush the brush
back as you pull it out. NO YOU SHOULD NOT BE USING the loader to
rip out the brush!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! USE the rear hitch
and a shackle sized for the rear hitch hole and use the proper sized
slip hooks with the 1/2 inch chain and brush grubber(s).
The other thing is you can purchase a 10,000 battery operated
12 volt winch to also pull out the brush very effectively from one position
over along distance using a roller fairlead to keep the winch cable in line
and prevent it from binding.
/ clearing understory - can I avoid the turtles? #19
Can't you do your work during the winter when the box turtles are hibernating? I would think that you could look up exactly when and how they survive the winter and work around that. I don't know for sure but I'll bet that they dig a hole and bury themselves down fairly deep out of harms way. Your relatively mild winter weather should give you plenty of opportunities to work on it while the turtles sleep away.
/ clearing understory - can I avoid the turtles? #20
Y'know what? The first thing I thought of when I read honeysuckle and ivy wasn't a brush hog, sickle bar or weedeater, it was GOATS. Seriously, if you know anybody with a herd of goats or ever considered owning some they will do a better job of clearing your underbrush, with zero worries about collateral turtle damage, than just about anything going. There are people who make good money renting out their goat herds for just that purpose. Just a thought.
