Mowing Clearing the radiator of debris
   / Clearing the radiator of debris #41
I recently purchased this from Amazon. It makes my other air guns look weak. I thought my radiator was pretty clean until I took this to it. Had to use a leaf blower to clean out the mess I made in my shop. I very seldom recommend items to purchase but this one is an exception. What I like best is it fits easily between the radiator, condenser, and oil cooler
Innovative Products of America 8051 Air Comb 24" Filter Cleaner
Thanks for the tip. I might pick one of those up. I'm thinking the 36" version might be better for my tractor. With the loader on, it's hard to get in there very close.
Since I started this discussion I wanted to give an update.
I did take the leaf blower to the property and used it on the the tractor. I did get quite a bit of debris cleared but it was still significantly clogged with dust. We hauled the tractor home since I needed to help mow my brother's property. Here we have a decent air compressor so started blowing it out with that and loosened the fan shroud to get better access to the back of the radiator. We got a ton of dust out it seemed to the point of wanting a a mask on. But on close inspection a lot of the vanes were still clogged with what looked like compacted dust. At this stage I decided to try the water hose with a sharp stream while cognizant of the warnings provided here about using water. This did work well, for a while it looked like mud was being flushed from the radiator vanes. I continued that until the water was clear then blew it out again with air. Now I can see light through the vanes:)
Hopefully now that the worst of the clogging debris has been cleaned out the leaf blower will work better keeping it cleaned.
Again I want to thank everyone for their input and suggestions, it was of great help.
2022 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2444 (A60432)
2444 (A60432)
2424 (A60432)
2424 (A60432)
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
5' ROTARY MOWER (A60430)
5' ROTARY MOWER...
