Mowing Clearing the radiator of debris
   / Clearing the radiator of debris #41
I recently purchased this from Amazon. It makes my other air guns look weak. I thought my radiator was pretty clean until I took this to it. Had to use a leaf blower to clean out the mess I made in my shop. I very seldom recommend items to purchase but this one is an exception. What I like best is it fits easily between the radiator, condenser, and oil cooler
Innovative Products of America 8051 Air Comb 24" Filter Cleaner
Thanks for the tip. I might pick one of those up. I'm thinking the 36" version might be better for my tractor. With the loader on, it's hard to get in there very close.
Since I started this discussion I wanted to give an update.
I did take the leaf blower to the property and used it on the the tractor. I did get quite a bit of debris cleared but it was still significantly clogged with dust. We hauled the tractor home since I needed to help mow my brother's property. Here we have a decent air compressor so started blowing it out with that and loosened the fan shroud to get better access to the back of the radiator. We got a ton of dust out it seemed to the point of wanting a a mask on. But on close inspection a lot of the vanes were still clogged with what looked like compacted dust. At this stage I decided to try the water hose with a sharp stream while cognizant of the warnings provided here about using water. This did work well, for a while it looked like mud was being flushed from the radiator vanes. I continued that until the water was clear then blew it out again with air. Now I can see light through the vanes:)
Hopefully now that the worst of the clogging debris has been cleaned out the leaf blower will work better keeping it cleaned.
Again I want to thank everyone for their input and suggestions, it was of great help.
2008 FORD F-350 SUPER DUTY (A58214)
2008 FORD F-350...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
Kubota MX5200 (A57148)
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
